kwahodi
Mikrotik Point to point Connection
Sat Feb 11, 2006 6:02 pm
I've recently acquired two Mikrotik (RIC/522) 5.1-5.8Ghz Integrated Router Antennae. I'm trying to acheive connectivity between two sites with a line-of-site distance of approximately 4kms. This point-to-pont connection is supposed to connect 2 LAN's so that they can use a central data base. I'm new to Mikrotik equipment and RouterOS.I would like some assistance with the configurations. I can't seem to get the configurations right. Thanks.
hkaiser
Sat Feb 11, 2006 11:47 pm
Please post your settings.
hkaiser
butche
Trainer
Trainer
Sun Feb 12, 2006 3:33 am
kwahodi
Tue Feb 14, 2006 8:53 am
This is what I've configured on either side:
LAN1 -IP address
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.0.1/24 192.168.0.0 192.168.0.255 ether1
1 10.0.0.1/24 10.0.0.0 10.0.0.255 wlan1
IP Route:
DST-ADDRESS PREFSRC G DIST INTERFACE
0 ADC 10.0.0.0/24 10.0.0.1 wlan1
1 ADC 192.168.0.0/24 192.168.0.1 ether1
2 A S 0.0.0.0/0 r 10.0.0.2 wlan1
Interface wireless is set to "p2p"
LAN 2 - IP address
0 192.168.0.2/24 192.168.0.0 192.168.0.255 ether1
1 10.0.0.2/24 10.0.0.0 10.0.0.200 wlan1
IP Route:
0 ADC 10.0.0.0/24 10.0.0.2 wlan1
1 ADC 192.168.0.0/24 192.168.0.2 ether1
2 A S 0.0.0.0/0 r 10.0.0.1 wlan1
I can ping the gateways from either side but cannot png the IP addresses. I think I'm supposed to set up NAT. How do you go about this based on the above settings? Thanks.
sergejs
Tue Feb 14, 2006 1:01 pm
Use this configuration example for transparent network over wireless nodes:
http://wiki.mikrotik.com/wiki/Transpare ... o_Networks
Do not forget to set NAT (masquerade) rule at the AP router,
'ip firewall nat add action=masquerade out-interface=iface_name'.
Borage
Tue Feb 14, 2006 6:42 pm
Not at all, you are trying to route from 192.168.0.0/24 to 192.168.0.0/24 and that is not possible. You must assign a different subnet on the other side i.e. 192.168.1.0/24 or anything else than the subnet 192.168.0.0/24.
kwahodi
Thu Feb 16, 2006 7:49 am
Ok...now I've managed to set-up a transparent bridge between the two networks. I can ping and access machines on either network. LAN 1 has an internet connection which needs to be shared to LAN 2. Access is via DNS and the adddresses are 80.240.196.24 and 80.240.192.14. How do I go about this? Thanks.
Borage
Thu Feb 16, 2006 4:33 pm
Add both DNS servers IP address and default gateways IP address to the DHCP servers configuration. If you don't have one, just add it to each clients TCP/IP configuration.
ronniee
Wed Nov 08, 2006 9:39 pm
Somebody can tell me what mode is the most perfect, for better speed with 2 RIC/522 in a 2 km link?
I have tested an "ap-bridge" - "ap-bridge" link with WDS, but i get only 5-6Mbit speed with bandwidth test
I have few links with "ap-bridge" - "client" no WDS mode and is working better than another settings.
I will test the "bidge" - "bridge" WDS connection, but i think with WDS the speed is lower, no?
thanks.
ronniee
Equis
Forum Veteran
Forum Veteran
Thu Nov 09, 2006 12:15 pm
Can you turn nstreame on and set framer policy and compression
I don't think wds works with nstream but eoip will
sergejs
Thu Nov 09, 2006 12:48 pm
WDS works with Nstreme in AP <-> station-wds configuration (Ap-bridge <-> Ap-bridge does not work), as well WDS does not work with Dual Nstreme.
balimore
Forum Veteran
Forum Veteran
Thu Nov 09, 2006 1:53 pm
@sergejs
do you have experinces,...what's better security [block] for other APs will try to connect to our network, i assumsy used AP-bridge to AP-bridge...?
thanks again, you are best friend and your time.! :wink:
and give me your experince for a little security....
regards
Hasbullah.com
sergejs
Thu Nov 09, 2006 3:14 pm
balimore,
AP-bridge cannot connect to another AP-bridge with default settings, connection between AP is possible with enabled WDS. If you have WDS enabled between AP to secure connection:
1) Disable 'default-authentication' and add WDS peers MAC-address to 'connect-list' (! not to access-list).
2) Enable encryption WPA or WPA2 between wireless interfaces.
balimore
Forum Veteran
Forum Veteran
Thu Nov 09, 2006 3:21 pm
balimore,
ofcourse, with WDS...and LOS
maybe next 17 days i will make new link AP-AP around 6,3km
Thanks for you experince, when you have other experince don't forget me for your advice...
regards
Hasbullah.com
Users browsing this forum: No registered users and 23 guests
