azurtem
Trainer
Trainer
IP plug and play
Mon Dec 03, 2012 3:47 pm
Hi
Is it possible to setup an RB device to act as DHCP server
and to pply IP plug and play distribution of addresses
i.e. even if the workstation is already equipped with a static
IP address, the server will 'allow' the workstation through ?
Or is is this solely a hotspot feature ?
thanks
yann
Discus
Re: IP plug and play
Thu Dec 06, 2012 11:03 am
As long as that IP address doesn't conflict with another, it should be OK as long as your firewall rules allow it.
I am of course assuming that the static IP addresses are something you know in advance (i.e. you use DHCP to hand out addresses from e.g. the bottom half of 192.168.1.0/24 and statically assign the top half), and not something people randomly assign to their device.
If the latter, it *may* be possible to set up a NAT on the interface to which those static devices connect that translates any random static address to something the router (and your internet connection) will be able to do something with, but this would be a pretty crazy setup.
azurtem
Trainer
Trainer
Thu Dec 13, 2012 10:57 am
Thanks for your reply Discus
I should have mentioned that the Zyxel hotpot devices (g4100 or n4100)
for example, and others aswell I'm sure, can assign an IP address to a
customer whether he/she is in DHCP mode or not.
That is the behaviour I was trying to obtain from the RB
possible ?
yann
Discus
Tue Dec 18, 2012 11:29 am
I can't imagine that Zyxel magically over-rides the client's DHCP mode; they must be doing some sort of (symmetric) NAT on such devices. This is more or less what I was talking about in the second paragraph - it's certainly possible to do this.
I suspect you may have to run some scripts to get this to work precisely as you wish it to (which I can't help you with, but you'd have to record the client's IP, then use that to build your NAT rules dynamically, which I suspect will be tricky).
It will be much easier if you don't want symmetric NAT (i.e. 1 of your addresses to 1 client address); if you tell the SRC NAT rule on your client-facing interface(s) to masquerade or src-nat <any IP that isn't one of yours> (address lists is usually the most flexible way), this should achieve similar functionality to what I suspect the Zyxels are doing. Incoming (dst-nat) rules will be rather more tricky and require you to know that address the end user is using. That said, routing could get extremely ugly, and I would suggest you tell clients they really ought to be using DHCP.
Good luck!
azurtem
Trainer
Trainer
Sat Dec 22, 2012 11:06 am
Thanks Discus for such a precise answer
Users browsing this forum: McSee and 108 guests
