Zalic
Home network
Thu Dec 06, 2012 11:17 pm
Hi! Is it possible build network with i draw in picture? inRB433 I will place 2 wifi cards, one for Ethernet, second for ethernet tv. For TV enthernet signal receive i will use RB411R
ohara
Re: Home network
Thu Dec 06, 2012 11:34 pm
Hi, if your TV set has an ethernet port then answer is yes. I am not familiar with internet TV operators in your country, but I can imagine such setup to work in combitation with MediaPortal/Plex Media Center and DLNA. If you have a streaming TV provider then your setup is indeed possible, even by the use of just one radio card in RB433.
Users browsing this forum: No registered users and 41 guests
