MUM Europe 2020
hulud
RB532 + RB564 + Six SR2 ????
Tue Feb 14, 2006 6:10 pm
RB532 + RB 564 + six sr2
Will it work at maximum power ?
Can someone say it for sure ?
cmit
Tue Feb 14, 2006 6:48 pm
Six SR2's is absolutely above the maximum electrical power the RB500 can provide...
Search the forum for relevant threads - this has been discussed here and on http://forum.routerboard.com, too.
Best regards,
Christian Meis
Best regards,
Christian Meis
hulud
Tue Feb 14, 2006 6:59 pm
48V power over ethernet won't help ?
wildbill442
Tue Feb 14, 2006 7:05 pm
Nope, RB500 series will support a recommended maximum of two SR2/5 cards. It's the limitation of the miniPCI slots.
cibernet
Long time Member
Long time Member
Tue Feb 14, 2006 10:49 pm
That´s right.. 2 cards MAXIMUN, using 48V and 30W powe supply....
Regards
José Ignacio Acosta
MikroTik Consultant IDAR0001
Mikronet
Movile: +54 9 3472-624722
Email/Msn: info[at]mikronet.com.ar
bholler
Trainer
Trainer
Sat Feb 18, 2006 4:31 pm
Please ciber, have u tried 2 SR2 on a RB500 before and did it ork perfectly.becuse this the main problem i have with a network design for a client of mine.
Mikrotik Certified Trainer Partner, MTCNA, MTCTCE, MTCWE, MTCRE. YIM: oseniabiola Skye: habholler1, Tel.+2348060319130, +2348182556717, Email: abiola@trisatcom.net
djape
Sat Feb 18, 2006 5:23 pm
4 cm9 cards work without problem!
2 SR2 cards are maximum for RB532!
I never tried two SR2 and two CM9 in RB532 so I can't give you any advice about that configuration.
Cheers...
I drink like a pirate and smoke like a hippie...
bholler
Trainer
Trainer
Sat Feb 18, 2006 5:38 pm
hello all,
i have a new client that already is already WISP using 2.4 GHZ platform with YDI radios with this he has ydi CPE radios in stock.... but he want my me to build a back backhaul link for him on 5ghz and later distribute again with 2.4 ghz. so i want to use rb530/2x sr2. with 2x 180 degree sectors or 4x 90 degres sectors with splitters.
my main concern is: how effective are 2 of SR2 cards on RB532 ?
how effective will it be to split one card into 2x 90 degress sectors
will 2x SR5 cards be effective too
cibernet
Long time Member
Long time Member
Sat Feb 18, 2006 6:45 pm
I have tried 1 SR2 + 1SR5 on RB532, and its working fine
Regards
José Ignacio Acosta
Mikronet
kiwi-chris
Sun Feb 19, 2006 10:52 am
I have a few set up
532 + SR5 and CM9
532 + SR2 and SR2 (on low output) and CM9
532 + SR5 and SR2
512 + SR2 and SR2
512 + SR2 and prism 200mw
All seam to work ok, but the 5.8 links are taking a bit to get sorted 100%
Back when the SR2 first came out I tried 4 and a CM9 and killed it. I have learnt from my mistake. :oops:
Like everyone says 2 Max
bholler
Trainer
Trainer
Sun Feb 19, 2006 4:20 pm
hello sirs,
thanks for the responses, please what if i try to use 2x sr2 and 1 x cm9 to achieve 3 sectors at 120 degrees
has anyone tried it that way ?
cibernet
Long time Member
Long time Member
Sun Feb 19, 2006 10:58 pm
hello sirs,
I don´t recommend you that... only if you power down one of the SR....
Regards
José Ignacio Acosta
Mikronet
Users browsing this forum: maurodx and 23 guests
