Bitto
Nstreme or Nv2. Is Nstreme Obsolete?
Fri Dec 28, 2012 12:33 pm
Hello guys,
After nv2 intoduced i get better throughput with moving my links to tdma but, i get more stable latency and throughput on nstreme links.
We know tdma superb on ptmp links, what do you recomend on ptp links nv2 or nstreme ? Is nstreme obsolete?
InoX
Re: Nstreme or Nv2. Is Nstreme Obsolete?
Fri Dec 28, 2012 5:24 pm
wich one is it? :D
all my links ptp and ptmp are nv2, it seems that N cards don't work very good with nstreme.
rado3105
Sat Dec 29, 2012 2:20 am
NV2 is very bad for ptp, causing high latency....mainly in noisy enviroment...there is nothing better for latency than dual-nestreme, or nstreme...
Bitto
Sat Dec 29, 2012 10:40 am
Yes also throughput is spikey on nv2.
Nstreme is more stable but some reason it did not work well with dual chains.
Why did mikrotik not solve this issue ? Did they abandon nstreme ?
If this is the case why do not they improve nv2 for ptp links?
Lakis
Forum Veteran
Forum Veteran
Sun Dec 30, 2012 3:13 pm
If someone can explain this :)
Why do I need nv2 for p2p - TDMA protocol is making time slots for every client but on p2p in general u have only one client
Bitto
Mon Dec 31, 2012 12:10 pm
It is making timeslots for each down/up channel one client may use all of them or several clients may share.. I just wanted to learn Is mikrotik spending time over nstreme? Are they still improve/developing it? Will they fix pool timeout issue on nstreme?
rado3105
Mon Dec 31, 2012 7:29 pm
This is big mystery....and mikrotik dont communicate with needs of clients...
Lakis
Forum Veteran
Forum Veteran
Mon Dec 31, 2012 8:22 pm
Yes it sound better but
most of my p2p links I m sure and yours are running nstreme because for me its better
about pool timeout issue and random disconnects I was writing and writing and writing until one day I was tired :):):) u can find million posts about that
hope they come out with something soon
Happy new year and best wishes...
normis
Wed Jan 02, 2013 1:11 pm
Nv2 should give you better speed. Nstreme in some cases could have better latency.
rado3105
Wed Jan 02, 2013 2:52 pm
Why nstreme is not working on N cards? Why dont you work on solving problems on N cards...this could bring you a lot of customers from ubnt....
Ciambot
Wed Jan 02, 2013 6:04 pm
Nv2 has better throughput and it is more stable, but major problem is that nv2 doesn't work in sequence: single connection drops drastically when traffic over links increases. http://forum.mikrotik.com/viewtopic.php?f=7&t=66380
Lakis
Forum Veteran
Forum Veteran
Wed Jan 02, 2013 9:15 pm
Actually nstreme is working good on N
but is much more sensitive on Noise only problem is disconnect issue - just my thought
just to add
On A cards dont have such problem
InoX
Wed Jan 02, 2013 11:29 pm
I have 4 ptp links and one ptmp with mikrotik. None works with nstreme. In fact they work but not as good as nv2. 2 links are with groove, one with RB711G and one with SXT.
DiabolixZA
Thu Jan 03, 2013 9:25 am
My experience is the following:
NV2 - Works well with N (MIMO and SISO) links. Higher trhoughput, and link stability is better. Although you get latency's that are not preferred. 2ms-20ms. Jumps all over the place,while sending data. I use NV2 on all my newer PTP links to get the throughput I want. All these links has a CCQ of 95% and up.
Nstreme - Works well with 802.11a, and 802.11g, turbo mode(40Mhz). If link works, you have awesome latency while sending data, <1ms. Throughput is high as well. We can only dream about using Nstreme on N links.. It just doesn't work..
I wish Mikrotik would work on a PTP protocol, because it seems they have dropped all support for the nstreme protocol..
rado3105
Thu Jan 03, 2013 7:21 pm
really true, this couldnt accept some mikrotik fanatics...
Hope if anybody has working dualnstreme on N cards(mimo) and if it is working in real.
mjoksimovic
Thu Jan 03, 2013 10:08 pm
NSTREME on N-links works perfectly, x86 hardware, SR71 od SparkLan198N mici-pci cards, MIMO, dual polarization. I don't see any problems with NSTREME on N-links, it works stable with excellent throughput in my commercial environment almost 2 years on more than 10 links.
"Your chances of success in any undertaking can always be measured by your belief in yourself". - Robert Collier
Lakis
Forum Veteran
Forum Veteran
Sat Jan 05, 2013 1:44 pm
Yes I agree nstreme works perfectly in stand point of speed and latency except disconnect problem witch I m bateling with this problem since 5.x OS
we are talking hire for p2p N dual links
What ver. of MT OS are u using 4.17 earlier 5.x? have u tried > 5.18,5.19... ver of MT OS?
rado3105
Sat Jan 05, 2013 2:39 pm
yes, which version of rOS do you use?
I tryed yesterday: one site: rb433ah +r52nM, other site: rb711-5hn-mmcx
one polarized antennas on both site, nv2 gives 40mbit/s, after changing to nstreme 2-10mbit/s.
ros 6rc6 and client v5.22.
http://i45.tinypic.com/1z20l83.jpg
pleasu could you specify more nstreme setting: hw-retries, frame policy..?
vasilaos
Wed Apr 09, 2014 2:13 am
nv2 does not give better speed in my case and nstreme is disconnecting because of pool timeout.
wispwest
Fri Apr 11, 2014 9:47 am
Nstreme had the lowest latency, 0-1ms. However seems ever since v6+ it crippled the performance of it...
vmnx
Sat Apr 12, 2014 5:59 pm
Agree, nstreme is total crap on v6. Do you guys know last stable ROS version that nstreme runs stable and with good bandwidth? I need to run this wireless link for a month before I can change it to UBNT gear...
pospanko
Sat Apr 12, 2014 9:59 pm
Is anyone tested nstreme from v6.7, when they updated it? I got some good results lately.
Internet, Mikrotik & Network solutions
http://www.pro-ping.hr
ste
Sun Apr 13, 2014 9:02 am
It depends. With low interference nstreme gives better results than nv2. NV2 works reliable but reduces tcp speed.
vmnx
Sun Apr 13, 2014 10:37 pm
I noticed that both works bad with chain 1 and 2 enabled. CCQ bad, rates 216-180mb/s... When enabled only chain 1, everything is ok, rates 150/150 CCQ 99-100. Maybe something is wrong with the link, I dont know, 700m CLOS, enough fresnel, interference low...
Users browsing this forum: rbilka and 38 guests
