Im setting up a 200m link with 2x RB711GA 5Hn, the antennas are StationBox Mikro, they have dual polarity, so does the RB711.
We have very good line of sight, the signal im seeing at the client end is tx/rx -57dbi/-56dbi
I have read the guide "Transparently bridge two networks using MPLS", but currently the setup is a traditional "AP and Client" link with ethernet to wlan bridges.
Wich is better? In my Lab i managed to get 300/300 Mbit in TX/RX rates, with bandwidth test getting 150-200mbits.. This was last year. Now when everything is installed at the locations, im getting 65/65 mbit at tx/rx rate. And the UDP bandwidth tests show 40-50 Mbit.
Should i revert back to the mpls/vpls config? Why arent I seeing the speeds that i should?
Also, what protocol should I be using? NV2 or Nstreeme? My tests shows nv2 gets slightly better speeds, but my latency is all over the place, with 2% loss. Nstreeme gives a very stable 4ms latency.
