Ginsu
MiniPci 802.11 N 2x2 Mimo
Fri Feb 22, 2013 5:03 pm
Where can i get a card with this TX power, this is the TX power from the SXT-5HPnD, i need a MiniPci card with this TX Power or similar.
Thank you
uldis
Re: MiniPci 802.11 N 2x2 Mimo
Fri Feb 22, 2013 5:05 pm
this the closest card that we could suggest, but it is single chain:
http://routerboard.com/R5SHPn
Ginsu
Fri Feb 22, 2013 7:58 pm
Yes Uldis i have a couple of them, but i need 2 chains cause 150Mbps/150Mbps isn't enough for what i need, and i need that kind of power cause the link is very long (50Km+)
U maybe can explain me why is possible to have that wireless card integrated to an SXT but is not possible to have it as a MiniPci Card or integrated in a bigger routerboard to use it with an external dualpol antenna like a dish or a grid.
Thank you for your time!
0ldman
Fri Feb 22, 2013 9:20 pm
DBII F50n Pro
I've got one here, so far so good.
ohara
Fri Feb 22, 2013 9:22 pm
+ 1
InoX
Sat Feb 23, 2013 10:59 pm
Buy another SXT-5HPnD, pull out from the plastic case, "unsolder" the antenna and solder two pigtails.
braidiano
Sun Feb 24, 2013 11:29 am
Use less power and a bigger antenna
jgellis
Sun Feb 24, 2013 12:15 pm
We used Ubiquiti's SR71-15 in our Routerboards. http://dl.ubnt.com/sr71_15_ds.pdf
Not precisely the same level of power output (2 to 4dBm lower), but you really are much better off turning down the power on your radios and installing better antennas. You can achieve better long distance link performance with the narrower beam widths of a higher gain antenna, and your power budget will thank you as well.
- If I helped you solve your problem... I am now able to accept tax-deductible Karma donations!
Ginsu
Tue Feb 26, 2013 6:43 pm
is there any chance to get a dish antenna that have more than 34db gain?
does anybody work or know this antenna?
http://www.telimart.com/pdf/antennas/di ... ISH-38.gif
0ldman
Wed Feb 27, 2013 6:38 am
How long of a shot is it?
hipro5
Wed Feb 27, 2013 8:42 am
Hmmmm........."Strange" diagram......It's like it tells you: "now you're f(l)ucked".....or something..... :D :lol:
Ginsu
Wed Feb 27, 2013 3:00 pm
It's a 54 Km link
Sergio72
Thu Feb 28, 2013 1:22 am
1,8m diameter and 38 dBi gain...
In the past (6-7 years ago) I had 1,5m dish, I used it in 2,4 GHz. We have very great antenna gain and the link was really impressive. But the most impressive was the dish "flight" when wind blew it off from the mast. Hopefully noone was hurt...
On the market there are some 32 dBi parabolic dish antennas, use them rather.
Sergio72
Thu Feb 28, 2013 1:23 am
The radiation pattern very interesting... it's right... :)
jayismyson
Sat Mar 30, 2013 7:02 am
How long of a shot?
_________________
Runescape Gold|Diablo 3 Gold|WoW Gold|Rs Gold
saintofinternet
Forum Veteran
Forum Veteran
Wed Jul 17, 2013 9:40 am
Telimart is a big name in the wireless industry in India.... you can bet by their antenna's.... it is good!!!!
by professionals, for professionals....
Don't forget to give KARMA!!!
saintofinternet
Forum Veteran
Forum Veteran
Wed Jul 17, 2013 9:42 am
How long of a shot?
54 kms " was told before 3 posts up "
Users browsing this forum: No registered users and 34 guests
