MUM Europe 2020
thomsany
Multiple RB433 deployment questions
Fri Mar 22, 2013 2:49 pm
Hi!
I am putting together a project to add about 45 RB433 antennas into a university campus.
I know how to set up APs so they have the same SSID, WPA2 password, etc but I am wondering if there is some sort of way to automatically change settings on all APs at the same time.
For example if one day I want to change the SSID globally I want to be able to do that on all of them at the same time and not one by one.
Also the issue with the WPA2 password, etc.
Is there a way to do this using a program or something? Or a script that can be run when changes are required? Is there a tool that does this already?
Hope there is one. It would be painfully slow to change each device separate.
Regards,
Teo
nick3dos
Re: Multiple RB433 deployment questions
Fri Mar 22, 2013 3:29 pm
It has been asked before,
i did it before, in my way...
maybe this will help you
http://forum.mikrotik.com/viewtopic.php?f=2&t=68881
thomsany
Fri Mar 22, 2013 5:03 pm
Thanks a lot! Will check it out!
Regards,
Teo
MacLean
Sun Mar 24, 2013 6:31 pm
Personally I think you'd be better off using RADIUS and not using WPA2. If it's a university you probably already have e-mail accounts or some existing IT infrastructure that could easily be extended to provide a seamless experience.
You might want to go further and have devices registered by MAC address.
Using RADIUS too would allow you to give out a certain periods of free internet. Homecoming. New student visit days. 15 minute trials.
And RADIUS will allow you control bandwidth usage per account.
-Mac
Users browsing this forum: No registered users and 27 guests
