tetecko
802.11n NV2 not more than 65Mbps/65Mbps
Sun Mar 24, 2013 11:39 am
I have 802.11n RB433AH+DBii-F50N-PRO on AP and client is Groove or RB411+R52Nm ..
NV2, 20MHz .. ROS 6.0rc11
Why is not connected more than 65Mbps/65Mbps? It looks like it use only long guard interval, why it not support short GI and then go to 72.2Mbps/72.2Mbps?
I try to search forum, somewhere is written, that NV2 not support short GI, somewhere that support short GI.
thanks in advance...
ohara
Re: 802.11n NV2 not more than 65Mbps/65Mbps
Sun Mar 24, 2013 12:08 pm
This post from Uldis confirms Nv2 wireless protocol supports short guard interval.
http://forum.mikrotik.com/viewtopic.php ... 18#p320792
On both AP and client use channel width: 20/40MHz, HT Guard Interval: any, protocol: nv2
and you should get tx/tx rate of 150Mbps/150Mbps
hipro5
Sun Mar 24, 2013 12:20 pm
What is the signal that you get and the quality CCQ Tx/Rx at the speed that you are locked (65Mbps)?
Nv2 SUPPORTS and works better (as for me at least) with Sort GI cofig.
tetecko
Sun Mar 24, 2013 7:00 pm
How can I set short GI ? I have HT Guard Interval = Any
this is same on Metal 5SHPn as AP .. which I send screenshot for some clients. Config is ...
name="ap_1" mtu=1500 mac-address=XXXXX arp=enabled disable-running-check=no interface-type=Atheros AR92xx
radio-name="XXXXXXX_AP1" mode=ap-bridge ssid="XXXXXXXXX" area="" frequency-mode=superchannel country=XXXXXXX
antenna-gain=0 frequency=5540 band=5ghz-a/n channel-width=20mhz scan-list=5470-5720 wireless-protocol=nv2 rate-set=default
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-a/g=6Mbps max-station-count=2007 distance=dynamic
tx-power=19 tx-power-mode=all-rates-fixed noise-floor-threshold=default nv2-noise-floor-offset=default periodic-calibration=default
periodic-calibration-interval=60 dfs-mode=none wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled bridge-mode=enabled default-authentication=yes default-forwarding=no
default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0 ht-guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-
18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-txchains=0 ht-rxchains=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192
tdma-period-size=4 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=10 nv2-security=disabled nv2-preshared-key="" hw-retries=7
frame-lifetime=0 adaptive-noise-immunity=none hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0
frequency-offset=0 rate-selection=advanced multicast-helper=default multicast-buffering=enabled
this is setting on last client from registration table screenshot
name="uplink_1" mtu=1500 mac-address=XXXXXX arp=enabled disable-running-check=no interface-type=Atheros AR92xx
radio-name="XXXXXXX" mode=station-bridge ssid="XXXXXXXXX" area="" frequency-mode=superchannel country=XXXXXX
antenna-gain=0 frequency=5180 band=5ghz-a/n channel-width=20mhz scan-list=5470-5725 wireless-protocol=nv2-nstreme-802.11 rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps
basic-rates-a/g=6Mbps max-station-count=2007 distance=dynamic tx-power=15 tx-power-mode=all-rates-fixed noise-floor-threshold=default
nv2-noise-floor-offset=default periodic-calibration=default periodic-calibration-interval=60 dfs-mode=none wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25
wmm-support=disabled hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=short
compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0 ht-guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,
tdma-period-size=2 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30 nv2-security=disabled nv2-preshared-key="" hw-retries=7
tetecko
Sun Mar 24, 2013 7:02 pm
And if I don't want to use 40MHz channel width?
hipro5
Sun Mar 24, 2013 7:26 pm
a. From the above screenshot with worst case -64db signal strenth, WHY do you lock at those LOW speeds? :?
b. Why don't you just pick as for the card's output Tx power its default settings?
c. How many clients are on this AP?
d. I see that you use "preamble-mode=short" as for the client, why's that?
tetecko
Sun Mar 24, 2013 7:44 pm
A) Don't sure for what you want to ask me for? :) Outdoor instalation - 20MHz, Metal 5SHPn = 1x1 MIMO
B) Outdoor is regulated here, we need to use maximal E.I.R.P, so I need to set maximal tx-power.
C) 20 registered clients right now, vary from 18 to 20 ...
D) Maybe it is lost configuration from past :)
hipro5
Sun Mar 24, 2013 8:39 pm
Maybe the AP "shows" the worst shenario of - let's say - 13Mbps/39Mbps from a client, and doesn't autochange to short GI config.
But why does a client lock at THAT LOW speed with -60/-63dB signal?........It should lock at the MAXIMUM speed.... :? The CCQ is very bad of it and that's the reason it locks LOW. :(
Why that low CCQ?....Isn't the client "shows" directly the AP?
At what maximum EIRP level you're obliged to transmit at your place?
tetecko
Sun Mar 24, 2013 11:36 pm
It is not problem with client you interested in :) if I start bandwidth test to him, rate will rise up :) EIRP here is 30dBm maximum. but rate never rise more than 65/65.
Users browsing this forum: No registered users and 27 guests
