MUM Europe 2020
shahin97
Some questions about mikrotik sxt/sextant
Thu Mar 28, 2013 11:03 am
Hello
  1. How we understand Ram Usage?
    How many client can use a sextant or sxt as router and dhcp server? (ether1 was connected to a switch and how many client/pc can connect to ether1?)
    Is need to enable ARP for sxt/sextant interface’s that has a bridge between wlan1 and ether1?
For ex: in this image
Routing is static
  1. How many client can connect to router B/C/D/A?
    Is need to enable ARP in the interfaces (ether1 and wlan1) of router E/F/G/H?
    Why after 2-3 hours some network will hang?
    Why some time the routers (sxt/sextant) need to restart(they doesn’t work)?
shahin97
Re: Some questions about mikrotik sxt/sextant
Fri Mar 29, 2013 5:19 pm
image edited
MacLean
Sat Mar 30, 2013 4:57 am
From the looks of your IP addressing I would imagine your subnetting is going to be your biggest limitation - not RAM or processing power.
I've seen 4 series Mikrotiks handle up to 80 hotspot users with an external RADIUS server with no issues.
-Mac
Ivoshiee
Sat Mar 30, 2013 2:18 pm
Subnetting? Are you kidding here? Pictured 2-3 subnets is nothing to be worried about.
Ivoshiee
Sat Mar 30, 2013 2:28 pm
Somehow I see no MikroTik devices on that picture - all Ciscos. If you indeed have issues with the MikroTik devices then you'll have to check the ROS version and dig around the forum here. Maybe that version is known to be faulty or you have found a new bug or two. If you want any support from the MikroTik then upgrade to the latest ROS version (try stable first then go for development one) and send in supout.rif files.
Note: I am a bit wary of the MikroTik bridging (there were times when that didn't work or just acted strange for me). If your configuration will allow then get rid of those bridges and adopt subnetting with static routes or if you dare to use MikroTik implementation of some higher level routing protocol then maybe try OSPF for route distribution.
Users browsing this forum: No registered users and 13 guests
