MUM Europe 2020
purvi
Mikrotik Dude Issue in 4.0beta3
Fri Apr 05, 2013 8:15 am
Dear team,
The link labels show the correct speed but graphs are showing 2x higher than they should.
In this pic I have put one bandwidth test of 5Mbps and found 5Mbps load on link and Mikrotik but when I see the Mikrotik dude graph
It’s double of 5 Mbps.
So please give me solution for this,
Thanks and Regards
Purvi
ohara
Odp: Mikrotik Dude Issue in 4.0beta3
Fri Apr 05, 2013 8:56 am
It only affects pc network card graphs. The Dude graph of your corresponding router ethernet port will show correct values, assuming that snmp is enabled on the router. I know it's not a fix, but a workaround is to monitor trafic on your router instead on your PC.
Users browsing this forum: Google [Bot] and 19 guests
