MUM Europe 2020
furuka
Point to Point bad CCQ
Thu May 16, 2013 4:15 pm
I've a point-to-point mikrotik wireless link using two groove with externel ant.
the link is quite good, the signal level are this:
-65 tx
-78 rx
CCQ 6/70 % (tx/rx)
signal to noise: 57db
but thw TX CCQ has no bandwith...
Can you help me what is wrong ?
Aug
Re: Point to Point bad CCQ
Thu May 16, 2013 6:37 pm
-78 is not what I would call good
Aug
samsung172
Thu May 16, 2013 6:40 pm
try to align your link
WirelessInstruments
Thu May 16, 2013 8:33 pm
Use stronger antennas or align them better.
http://www.wireless-instruments.com/
Antenna professionals, custom antennas for any application.
WiBOX antenna manufacturer.
Skype ID: wireless-instruments
furuka
Sat May 18, 2013 5:42 am
I've two 29 dbi dishes on both sides, I think there is something wrong with N configuration or HT MCS config....
furuka
Fri May 24, 2013 6:10 am
Ok, I solved the problem... we adjust some features in MCS and now we have 99/98 CCQ with 102/94 mb
Nothing about aling and all that stuff....
n21roadie
Fri May 24, 2013 11:34 am
Can I ask which features did you adjust which solved this issue?
N21roadie,
Network 100% MT for Now?
wirelesswaves
Fri May 24, 2013 9:18 pm
+1
Intrigued ???????
lorenzesz
Thu Jul 11, 2013 1:30 am
I have 1 km, good signal, los and 6% ccq. What have you done?
Users browsing this forum: No registered users and 13 guests
