Hello, have anyone experienced this before:
-on a building (outside) I have 4 Metal2SHPn for WIFI coverage (with the same type of UTP, distance, settings), acting just as AP.
2 or them work perfect!, the other 2 have a weird problem, WIFI interface stops working after 1-2 days, the device works, but not the wireless card, it stops sending SSID, on SCAN button it detects no networks , the only way to make it work again is to restart the device and then it will fail again on the first or second day.
The ethernet cable is around 50 meters, (UTP 5e), PoE is attached to a UPS, RouterOS is 6.1, I have tried lowering down the WLAN power, device speed to 250mhz(to reduce heat and consumption), Health reports 41 degrees and 21.5v PoE, I have tried all this and same results.
Any suggestion? Thank you in advice
