andreas140265
Simple AP not working, please help
Fri Jul 26, 2013 2:40 pm
This supposed to be a very simple setup, but.....
I have a 433AH with two radio cards:
one to connect wireless to my Backbone, and
one to work as an AP for clients
Here is my setup:
Connections are ok, the wlan1, wlan2 are bridged
with a DHCP client running on that bridge.
The bridge interface gets a valid ip, dynamic routes are created (ok),
the client computer also gets a valid ip, gateway, BUT client cannot
access anything but the 433AH. Not even the modem.
From inside 433AH using ping I can access everything but the
AP clients are totally blind.
This has to be a routing isssue, please help
Compact export follows,
thanks in advance
jul/26/2013 13:55:53 by RouterOS 6.1
# software id = CCQW-V3DZ
add l2mtu=2290 name=bridge1
add authentication-types=wpa2-psk eap-methods=passthrough \
management-protection=allowed mode=dynamic-keys name=10293847 \
supplicant-identity="" wpa2-pre-shared-key=10293847
/interface wireless
set 0 country=greece disabled=no frequency=5500 l2mtu=2290 security-profile=\
10293847 ssid=AAAAA wireless-protocol=unspecified
set 1 antenna-gain=3 band=2ghz-b/g country=greece disabled=no frequency=2412 \
l2mtu=2290 mode=ap-bridge security-profile=10293847 wireless-protocol=\
unspecified
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
mac-cookie-timeout=3d
/port
set 0 name=serial0
/tool user-manager customer
add backup-allowed=yes disabled=no login=admin password="" \
paypal-accept-pending=no paypal-allowed=no paypal-secure-response=no \
permissions=owner signup-allowed=no time-zone=-00:00
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=wlan2
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=bridge1
set allow-remote-requests=yes
/ip service
set api disabled=yes
/system clock
set time-zone-name=Europe/Athens
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set bridge1 disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
set wlan2 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
/system ntp client
set enabled=yes primary-ntp=194.177.210.54 secondary-ntp=147.102.224.241
cbrown
Trainer
Trainer
Fri Jul 26, 2013 11:55 pm
On the "backbone" you will either need to use WDS or you could use station-bridge if it is connecting to another MikroTik.
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
andreas140265
Re: Simple AP not working, please help
Tue Jul 30, 2013 2:43 am
Ok, WDS but how?
The backbone AP is not Mikrotik (Repeatit BS11) and there are no WDS params to configure for the AP.
The only WDS params I see are in the Mikrotik station. And I'm not sure how to config.
The only solution I've found till now is to use station-pseudobridge mode but I really would like
to have a real transparent bridge. Is this so difficult? Is it possible?
Rudios
Forum Veteran
Forum Veteran
Tue Jul 30, 2013 10:25 am
Are the DHCP supplied IP's coming from your DSL modem?
How is the RepeatIT BS11 connected IP wise?
Is there maybe some NAT'ing problem?
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
Users browsing this forum: No registered users and 32 guests
