letabawireless
PCC classifier
Thu Aug 22, 2013 9:31 am
Hi
Which PCC classifier have you found to be best ? I battle to get Youtube to continiously stream. Is there a way to adjust the timeout of when the PCC loses the established connection ?
W
macgaiver
Re: PCC classifier
Thu Aug 22, 2013 9:39 am
PCC is load balancing based on streams, you can not limit part of stream with it. for that you need to use other options, like "connection bytes" for example. it is common practice to prioritize first few megabits of all connection.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
letabawireless
Re: PCC classifier
Thu Aug 22, 2013 9:43 am
Cool, where and how would I set this up correctly ?
Many thanks for your advice !!
Estiaan
Re: PCC classifier
Thu Aug 22, 2013 4:03 pm
I am using Both Adresses and Ports,
so far all my youtube streams no problems, I have not yet tried all the banking sites, tho I know FNB works perfect, I think ABSA might be an issue.
What I have also seen is doing a speedtest using Both Adresses and Ports, "bonds" the PPPOE aswell, I was getting 15Mbps using PCC and two 10Mbps ADSL lines.
Users browsing this forum: No registered users and 23 guests
