MUM Europe 2020
mauricioisp
RB912UAG-5HPnD-OUT throughput?
Sun Sep 22, 2013 6:59 am
Hi guys,
I'm considering to replace my Rocket M5s with the RB912UAG-5HPnD-OUT, I'm using 30dBi antenna and I've -50dBm signal strength, what would be the expected throughput with the RB912UAG-5HPnD-OUT?
Thanks,
laithmikrotik
Re: RB912UAG-5HPnD-OUT throughput?
Sun Sep 22, 2013 11:46 am
just use nv2/nsetrem wireless protocol and adjust noise floor threshold to -120/-124 and remember ; you can not use rb912 as a point to roocket m5 , you should use ptp with two mikrotik devices...
I LIKE MIKROTIK
InoX
Sun Sep 22, 2013 11:50 am
At least 170mbps.
mauricioisp
Sun Sep 22, 2013 5:59 pm
Hi inox,
That's pretty similar to the 160mbps aggregated throughput I can get with 2 rocket m5 in p2p. I was thinking of 200mbps+ performance, such as ligowave pro.
popcorrin
Sun Sep 22, 2013 9:12 pm
Hi inox,
Just because the internal speedtest on airos shows 160mbps, that doesn't mean you can actually get that kind of throughput with a rocket m5.
With real traffic, you would be doing good to get 100mbps of actual throughput.
mauricioisp
Mon Sep 23, 2013 2:59 am
Why should I adjust noise floor threshold to -120/-124 ?
Thanks,
laithmikrotik
Mon Sep 23, 2013 10:39 am
Thanks,
to get high rx/tx signal strength with rx/tx ccq....i use this method just with ptp ................
I LIKE MIKROTIK
n21roadie
Mon Sep 23, 2013 2:37 pm
Thanks,
Interesting tweak, currently testing on a PTP which was 58/56dBm and 59db SNR, now using -120 noise floor i have 50/52dBm and 68SNR, CCQ appears to much higher from 80% to 100% but as this link is not fully aligned I will wait till it is but a increase in signal and snr it's most welcome.
N21roadie,
Network 100% MT for Now?
Users browsing this forum: No registered users and 21 guests
