mehdiTik
Metal2SHPn on the tower problem
Sun Oct 13, 2013 3:06 pm
Dear all
I have mounted a Metal2SHPn device on the tower with 40m high. The POE device(I have used the original POE device sold by factory 24v/1A) is connected with 50m cat6 cable to the AP. My Antenna is 15dbi ALFA omnidirectional.
My problem is that changing the settings of the device (for example change the frequency) takes a long time to apply (I check this with my laptop)
But when I have tested this device in our office, the changes applied very fast.
Also the ping time(from client to AP) is not good in channel 1-13 but it is good in channel 14.
My position in testing is 50-100m long from the tower.
Any help will be appreciated
MikroUser
Re: Metal2SHPn on the tower problem
Wed Oct 16, 2013 9:37 pm
For distances more than 20m you need protected cable, like that.
and check the voltage on your routerboard. for me original poe adapter was bad..very bad. and i use ubiquti poe adapter from bullet m2
cbrown
Trainer
Trainer
Thu Oct 17, 2013 3:36 am
That is also too far for passive PoE. 100ft (approx 30m) is about the max for passive.
C.Brown
cbrown[at]cbrown.co
Telegram: @chris4brown
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
lunchboxrts
Thu Oct 17, 2013 8:41 am
100ft max? We have plenty of runs 150+ with a good passive poe and they work fine. If your going very far don't use the mikrotik or ubnt poe's, get a good one
0ldman
Thu Oct 17, 2013 9:58 am
Mind clarifying that a bit?
cbrown
Trainer
Trainer
Thu Oct 17, 2013 2:20 pm
C.Brown
cbrown[at]cbrown.co
hipro5
Sat Oct 19, 2013 4:33 pm
I've recently used ~65m SFTP CAT6 cable on an RB411AH with a F50NPRO on it, powering it through an RB750UP and it works like charm! :)
Users browsing this forum: No registered users and 52 guests
