MUM Europe 2020
WirelessRudy
snooper tool - manual please!
Sat Nov 30, 2013 2:53 am
Has anybody any idea on what the 'snooper' tool in winbox is actually telling us?
And what the different pictograms mean?
If I snoop against my own network I see that snooper gives the same picto to either a cpe or an AP.
But other units get another sign.
Than I see some trapped level units. Does this mean cpe connected to AP? Makes no sense because some have even 3 levels....
There is this column "Networks". But its either "0" or nothing mentioned on my own MT-ROS routerboard driven network???
Same for the column "Stations". Only one of my AP's is showing the correct no. of stations... but the rest is showing nothing or "0"?
I think it can be a great tool, if it at least was documented.....
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
gniers
Re: snooper tool - manual please!
Wed Dec 04, 2013 5:54 pm
I have the same question.
I'm trying to use snooper via CLI and save the results to a file or syslog
/interface wireless snooper snoop wlan1 interval=00:00:01.000 append file=wifitest1
In Winbox you can select display: all/stations/frequencies/networks
Can you select this on the CLI ?
You can define: Interval -- 00:00:00.020..00:00:05 (time interval)
I assume that this is something like the duration parameter with the wireless scan
http://forum.mikrotik.com/viewtopic.php?f=9&t=44323
scan works but gives me not the needed information. Snooper via winbox does but now how do i get these results to a file or syslog or ..
I didn't manage to get it working.
A kind of manual or some suggestions how to realise this would be of great help.
thanks in advance
Gerard
soundsticks
Mon Jan 26, 2015 7:43 am
Anyone getting this work out, I'm looking this as well. Please
WirelessRudy
Mon Jan 26, 2015 12:31 pm
Well, as you can see on the data of my first post, its been a while. But never got an answer though.......
Rudy R. Puister
Users browsing this forum: No registered users and 31 guests
