variable
Wireless bandwidth limiting
Sat Apr 29, 2006 10:27 pm
Is there any way for mikrotik aps to allow and then bandwidth limit each connecting user based on mac from a radius serveR?
sergejs
Sun Apr 30, 2006 3:53 pm
What are your clients ?
If clients are MikroTik RouterOS, than use 'access-list' and 'AP TX' and 'Client TX' limits.
If clients aren't MikroTik routers, use mangle and queues.
variable
Sun Apr 30, 2006 11:14 pm
not mt clients.
and i mean something automatic. like, client with mac x connects, so the mt ap checks in radius if client x is allowed, and what Rate-Limit is for that client and creates a simple queue. is this doable?
ofasa
Mon May 01, 2006 1:10 am
Yes
variable
Mon May 01, 2006 1:23 am
how?
I tried setting Rate-Limit same as it was in dhcp, but when the client connected, no simple queue was created?
ofasa
Mon May 01, 2006 2:55 pm
Do you use fixed IPs for your clients? You could these through DHCP and use the DHCP Rate-Limit.
variable
Mon May 01, 2006 8:49 pm
yes, i would like to use fixed ips as opposed to dhcp as i have had some problems with clients leases renewing with dhcp.
is dhcp the only way, or can i get it to work with wireless?
Users browsing this forum: Baidu [Spider] and 16 guests
