Hi Cutty!I tried this script yesterday on a hAP-Lite. Obviously the 5GHz part didn't work as the radio is only 2GHz but other than that it worked ok.
The only issue I have is that the virtual ap stops working the the wan ap client is not connected. Is there a way to keep the inside ap operational so that registered devices can still communicate with each other when the wan ap client is down?
What did you change or modify to use it with hAP-lite? Truth be told, I would really like to know what is going on in the script as I am new to ROS. That is, a step by step to see what exactly I am configuring.
I have a hAP lite connected to an AP, but it is in station-pseudobridge mode AKA as a client. I used this guide: http://wiki.mikrotik.com/wiki/Connect_t ... ss_Network
If I could get a virtual AP working from here... life would be good!
