MUM Europe 2020
Equis
Forum Veteran
Forum Veteran
New Link 60kms, 3 hops, all Mikrotik
Wed May 03, 2006 1:31 pm
26 & 29dbi grids, cm9's set to 10db
-80 most of the way
Packets: Sent = 5069, Received = 5069, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 9ms, Maximum = 210ms, Average = 11ms
And its raining outside
What more can I say!
Thanks for all your hard work Mikrotik
wildbill442
Wed May 03, 2006 6:34 pm
why set the CM9 to 10dB? Local regulatory requirements? -80 dB doesn't leave much of a fade margin, and your ping times could be better. Are you using 5GHz or 2.4GHz?
Equis
Forum Veteran
Forum Veteran
Thu May 04, 2006 1:25 am
Yea, not allowed more than 30 at the end of the antenna.
5.8 Ghz
Still need to align the antenna's, I was very pleaseed with the outcome :-)
philjo
Fri Aug 18, 2006 4:13 pm
thats nice. PLz i would like to know if the radios are outdoors or indoors and wat boards are you using?
odie
Sat Aug 19, 2006 2:46 am
how long are the links ?
we have a few 17 to 23 km links with about 25 to 30db signal to noice and also 30db power at the antennas (huber&suhner 23dbiflat panel)
matt
Sat Aug 19, 2006 4:49 am
We did some testing a couple of days ago. I am very happy with the results.
Using the intergrated 22dBi RB112 series antenna with an SR5 radio card.
We were able to connect over 40kms with bandwidth tests of up or download speeds of 6Mb.
I was on the flat with the antenna mounted 2M high on the car pole we use for testing.
This was connecting to a 16dB Sector with 5M Heliax coax to a WRAP with an SR5 radio card on a 200M hill.
Both ends running 26dBm with -81 to -83 Rx at each end. SNR of 15.
Users browsing this forum: MSN [Bot] and 34 guests
