samir
i want hellp
Fri Mar 07, 2014 1:08 am
hi all
i have problem in mikrotik rb 912 p2p 6 km with dish antenna 30 dbi the CCQ is not good some time CCq is go to 50% i tray Change frequency but its same any 1 can hellp me pls coz its make me crazy
Thank you
shahbazian
Trainer
Trainer
Re: i want hellp
Sat Mar 08, 2014 12:24 am
hi all
Thank you
Hi
Use Spectrum analyzer to get best (clear) frequency.
please read this article:http://wiki.mikrotik.com/wiki/Manual:Spectrum_analyzer
Learn MikroTik to improve your network.
( MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCIPv6E, MTCINE )
MikroTik Certified Trainer & Consultant
RIPE NCC Trainer
samir
Re: i want hellp
Tue Mar 11, 2014 6:49 pm
i tray the good 1 and now its 44-
but the ccq not good any 1 have Information About installation RB 912 or can hellp me in teamviewer
Regards for all
nawas
Re: i want hellp
Thu Mar 13, 2014 3:07 pm
Hi.
Can you post your PTP configurations. and your antennas brand and model.
samir
Re: i want hellp
Thu Mar 13, 2014 5:04 pm
Hi.
hi
yes my friend
antennas is dish ubnt 30 dbi
this is configurations in pic
i tray many configurations but its same ccq bad and net bad this configurations The distance its 9 km
Is there a video programming RB912 p2p ?
samir
Re: i want hellp
Mon Mar 17, 2014 9:54 pm
Hi.
no 1 can hellp me ? is this RB912 have problem ?
rextended
Re: i want hellp
Mon Mar 17, 2014 10:03 pm
DECREASE THE POWER!!!!
-43 is too high!
30dB dish for 9 Km is excessive.
[My P2P with 28dBm dish, dual polarized, RB433AH + RB52Hn at 23,5Km do 180Mb/s effective with NV2 and 20MHz + 20MHz channel]
For link less than 10Km I use Sextant...
For link less than 5Km I use SXT...
The signal strength must float between -66 to -63 for optimal performance, or you obtain more ROS (return of signal) than 1:1
DO NOT USE WPA or TKIP as CRYPTOGRAPHIC PROFILE, but only WPA2 AES-CCM
Also, I see some error in wireless config, use my example for max throughput:
http://forum.mikrotik.com/viewtopic.php ... 75#p411390
YOUR DISH ARE DUAL POLARIZED?
IF ARE DUAL POLARIZED HT must transmit and receive on both channel 0 and 1
IF ARE SINGLE POLARIZED HT must transmit and receive only on channel 0 and NOT on 1 [and also the module must be properly internal connected]
Remember to set: country=italy with your country!
I'm Italian, not English. Sorry for my imperfect grammar.
PeterSullivan
Re: i want hellp
Wed Mar 19, 2014 2:01 pm
Hi
Hi Thanks for the DUal Polarized information.
I was unaware with this and that is why my CCQ float too much. Thanks for the information.
samir
Re: i want hellp
Wed Mar 19, 2014 8:24 pm
Hi
so bad i dont like RB912 :?
rextended
Re: i want hellp
Wed Mar 19, 2014 8:29 pm
samir
Re: i want hellp
Wed Mar 19, 2014 8:30 pm
-43 is too high!
this is my dish
and i have other link 30 km but its ubnt rocket m5 ccq is 99% and its so good
why this Mikrotik is like this bad ?
rextended
Re: i want hellp
Wed Mar 19, 2014 8:32 pm
-43 is too high!
re-read my previous post.
samir
Re: i want hellp
Wed Mar 19, 2014 8:39 pm
-43 is too high!
my frind i have other link 25 km its same ccq is so bad in same dish 30 dbi and RB912
u have skype ?
shahbazian
Trainer
Trainer
Re: i want hellp
Sat May 17, 2014 2:34 am
u have skype ?
Yes, I do support by skype, teamviewer and so on in free time.
My skype ID: vahid.shahbazian
Email address: vahid.shahbazian@gmail.com
RIPE NCC Trainer
Users browsing this forum: Bing [Bot] and 38 guests
