MUM Europe 2020
econst
X86 and Soperchannels
Fri Mar 07, 2014 10:31 pm
Is it possibel to use Superchannels on a X86 system aor only on RB? TIA
rextended
Re: X86 and Soperchannels
Fri Mar 07, 2014 10:53 pm
It's available from RouterOS 4.3 on all platforms.
The only thing not available on x86 version of RouterOS are NV2
I'm Italian, not English. Sorry for my imperfect grammar.
econst
Fri Mar 07, 2014 11:42 pm
Thanks fo your response, but are you 100% sure? I have a X86 system running ROS 5.23, but it does not have "Frequency mode" under the Wireless section. Have you tried it on a X86 system. I can see it on a RB. Pls confirm.
rextended
Fri Mar 07, 2014 11:56 pm
For see "frequency-mode" you must click first on the button on the bottom "Advanced Mode"...
I can not confirm on 5.23, I have 6.7 on my x86.
You also must have compatible atheros chipset!!!
I do not know all the single chipset vendors and models supported.
econst
Mon Mar 10, 2014 9:18 pm
Silly me. I see it now.
I read that you need chipset AR92xx to be able to use this feature on oth ends. Can someone recommend a good high power 5Ghz card that uses the AR92xx chipset or better. TIA
normis
Tue Mar 11, 2014 12:56 pm
plisken
Sat Mar 15, 2014 1:54 pm
Hallo Normis R52Hn are verry good cards.
Users browsing this forum: arjanwixx and 44 guests
