I am getting some BaseBox 2GHz MiMO 1000mW Access Point. I have been looking for some high gain antennas to put on them, 10dbi to be exact. I have only found the regular n-male or n-female antennas at this gain. I also found some Hyperlink Tecnologie "L-Com" 9dbi rubber duck antennas with already the rp-sma connectors with it.
Can someone tell me what the difference is between a regular omni n-male or n-female antenna and the rubber duck antennas? Meaning not that one is 9 and other is 10 dbi, lets assume they are both 9dbi, its there going to be a difference in performance? Or is ts the same?
Thanks,
