ficovh
BaseBox5 PtP 20km wireless link
Thu Mar 27, 2014 12:21 am
Hi folks
Recently I bougth a pair of BaseBox 5 with ARC Wireless 30dbi antenna for point to point link (~25km), whenver I have some questions:
1) How can turn on the leds in the AP side while the antena pointing aligment ?
2) I have low signal strength, the antennas are correctly aligment, same link with Rocket M5 /30dbi antennas get -65dbm
The BaseBox's are configured as Bridge->Station pseudobridge with NV2
That's all.
Thanks for reading my post.
rextended
Re: BaseBox5 PtP 20km wireless link
Fri Mar 28, 2014 2:15 am
25km? At this distance, if both radios are perfectly configured and aligned (and Fresnel Zone respected), you can reach 180Mbps @ 20MHz + 20MHz with 5GHz-n with NV2
Fresnel Zone:
http://en.wikipedia.org/wiki/Fresnel_zone
1) You can not.
2) ...
Why use Bridge->Station pseudobridge???
If are a PtP you MUST use (ap-)bridge + wds -> station wds for better performance.
I'm Italian, not English. Sorry for my imperfect grammar.
ficovh
Fri Mar 28, 2014 6:11 am
Hi.
Thank you for reply.
Now the antennas are correctly aligned, the signal strength is ~59dbm, my problem basically was resolved when I activate the chan1 in both sides TX/RX.
Thanks once more time.
nickshore
Sat Mar 29, 2014 2:21 pm
You should use Bridge - Station Bridge for a transparent L2 link between RBs
There is no need to use wds
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
ficovh
Tue Jun 03, 2014 5:49 pm
Thank you for the replies
Finally, I actived the chan2 in the BaseBox and the signal strength was -65.
Whenever I has low CCQ.
Tha AP heigth is 15 m and the client side 12 mt
using ap-bridge -> station wds
I put the screenshot : http://postimg.org/image/vd1s5qf1l/
Best Regards.
Jfabiopd
Wed Jun 04, 2014 5:02 am
Check the fresnel, i have a link that is in the same conditions, but with a capacity of 95/95 Mpbs or 190 Mpbs agreg. (limited by a poe patch panel 10/100Mpbs). The CCQ is about 95% and the signal -57dbm. the antennas are 30DBi dishes, without radome and shields.
If u need some help, just call.!!!
shailparmar
Wed Sep 30, 2015 7:40 am
We have same condition but very low throughput. Please share ur configuration.
Users browsing this forum: No registered users and 23 guests
