blingblouw
cap keeps disconnecting
Tue Apr 08, 2014 12:48 am
Anyone else having issues with cap disconnecting from manager?
I have 2 running fine but the 3rd one (on the same segment) keeps disconnecting from caps manager.
23:36:47 caps,info [::ffff:172.21.1.10:56706,Dead,[D4:CA:6D:B3:7D:BF]] disconnected
23:36:47 caps,info [::ffff:172.21.1.10:41834,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:37:17 caps,info [::ffff:172.21.1.10:41834,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:37:20 caps,info [::ffff:172.21.1.10:45746,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:37:50 caps,info [::ffff:172.21.1.10:45746,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:37:53 caps,info [::ffff:172.21.1.10:44437,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:38:23 caps,info [::ffff:172.21.1.10:44437,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:38:25 caps,info [::ffff:172.21.1.10:33340,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:38:55 caps,info [::ffff:172.21.1.10:33340,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:39:06 caps,info [::ffff:172.21.1.10:40362,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:39:36 caps,info [::ffff:172.21.1.10:40362,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:39:39 caps,info [::ffff:172.21.1.10:34872,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:40:09 caps,info [::ffff:172.21.1.10:34872,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:40:11 caps,info [::ffff:172.21.1.10:57956,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:40:41 caps,info [::ffff:172.21.1.10:57956,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:40:44 caps,info [::ffff:172.21.1.10:57085,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:41:14 caps,info [::ffff:172.21.1.10:57085,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:41:20 caps,info [::ffff:172.21.1.10:51355,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:41:51 caps,info [::ffff:172.21.1.10:51355,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:41:53 caps,info [::ffff:172.21.1.10:48039,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:42:23 caps,info [::ffff:172.21.1.10:48039,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:42:26 caps,info [::ffff:172.21.1.10:60180,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:42:57 caps,info [::ffff:172.21.1.10:60180,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:43:00 caps,info [::ffff:172.21.1.10:57976,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:43:30 caps,info [::ffff:172.21.1.10:57976,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:43:34 caps,info [::ffff:172.21.1.10:52199,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:44:04 caps,info [::ffff:172.21.1.10:52199,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:44:06 caps,info [::ffff:172.21.1.10:56188,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:44:36 caps,info [::ffff:172.21.1.10:56188,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:44:38 caps,info [::ffff:172.21.1.10:45296,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:44:39 system,info log rule removed by admin
23:44:40 system,info log rule removed by admin
23:44:44 system,info log rule added by admin
23:45:06 caps,debug [::ffff:172.21.1.10:48884,Idle] Idle->DtlsSetup
23:45:08 caps,debug [::ffff:172.21.1.10:45296,DataCheck,[D4:CA:6D:B3:7D:BF]] DataCheck->DtlsTeardown
23:45:08 caps,info [::ffff:172.21.1.10:45296,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:45:08 caps,debug [::ffff:172.21.1.10:45296,DtlsTeardown] DtlsTeardown->Dead
23:45:09 caps,debug [::ffff:172.21.1.10:48884,DtlsSetup] DtlsSetup->Join
23:45:10 caps,info [::ffff:172.21.1.10:48884,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:45:10 caps,debug [::ffff:172.21.1.10:48884,Join,[D4:CA:6D:B3:7D:BF]] Join->Configure
23:45:10 caps,debug [::ffff:172.21.1.10:48884,Configure,[D4:CA:6D:B3:7D:BF]] Configure->DataCheck
23:45:38 caps,debug [::ffff:172.21.1.10:36216,Idle] Idle->DtlsSetup
23:45:40 caps,debug [::ffff:172.21.1.10:48884,DataCheck,[D4:CA:6D:B3:7D:BF]] DataCheck->DtlsTeardown
23:45:40 caps,info [::ffff:172.21.1.10:48884,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:45:40 caps,debug [::ffff:172.21.1.10:48884,DtlsTeardown] DtlsTeardown->Dead
23:45:41 caps,debug [::ffff:172.21.1.10:36216,DtlsSetup] DtlsSetup->Join
23:45:42 caps,info [::ffff:172.21.1.10:36216,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:45:42 caps,debug [::ffff:172.21.1.10:36216,Join,[D4:CA:6D:B3:7D:BF]] Join->Configure
23:45:42 caps,debug [::ffff:172.21.1.10:36216,Configure,[D4:CA:6D:B3:7D:BF]] Configure->DataCheck
ping is 42ms average with 0% packet loss. Its a routed network and they are communicating directly with the IP (no DNS)
MichelePietravalle
Trainer
Trainer
Re: cap keeps disconnecting
Thu May 08, 2014 1:49 am
i have the same problem! today i will open a ticket to mikrotik.
the problem is the same with ROS 6.12 and with ROS 6.13rc14
MichelePietravalle
Trainer
Trainer
Thu May 08, 2014 7:36 pm
the problem (for me) is about ROS on x86. with the CAPmanager installed on mipsbe works fine!
cdiedrich
Forum Veteran
Forum Veteran
Fri May 09, 2014 1:27 pm
Any certificates involved?
Does the CAPsMAN provide a certificate?
If so, make sure the CAPsMAN's CA cert is also present on the CAPs.
Cheers
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
blingblouw
Fri May 09, 2014 3:56 pm
No Certs involved.
Anyway, given up on caps till html5 ios bug is sorted
uldis
Fri May 09, 2014 4:28 pm
No Certs involved.
This problem is fixed in new RouterOS v6.13rc test build, please contact support@mikrotik.com to access the development version of the CAPsMAN to test it out.
blingblouw
Fri May 09, 2014 5:32 pm
Thanks, thats the plan. However I'm going to wait a while, ROS6.12 forum post is 5 pages long, not about to start installing RC stuff just yet ;)
Users browsing this forum: No registered users and 36 guests
