azurtem
Trainer
Trainer
RB951 vertical or horizontal position
Tue Apr 15, 2014 6:29 pm
Hi
The underside of the RB951 is equipped with two
screw holder holes, as well as four rubber pads.
I therefore assume that the device can either be
wall mounted or positioned on a flat surface.
Has anyone noticed any difference in signal
propagation whether it is placed in one or the
other position ?
thanks
yann
rextended
Re: RB951 vertical or horizontal position
Tue Apr 15, 2014 8:53 pm
Really I do not notice any difference...
I'm Italian, not English. Sorry for my imperfect grammar.
Users browsing this forum: kamild1996, tinka and 56 guests
