MUM Europe 2020
bhickey
Connection refused
Mon May 22, 2006 1:24 pm
I've seen this question asked before but have seen no solutions. I have a 2.9.24 RouterOS unit whose ethernet IP I can access no problem via SSH, WWW, FTP etc. but I can't connect using Winbox on the same IP. I can connect using Winbox on it's Wireless interfaces okay but not on its ethernet interface.
cibernet
Long time Member
Long time Member
Re: Connection refused
Mon May 22, 2006 1:49 pm
Check if there is some firewall rule that is blocking port TCP 8291..
Regards
José Ignacio Acosta
MikroTik Consultant IDAR0001
Mikronet
Movile: +54 9 3472-624722
Email/Msn: info[at]mikronet.com.ar
bhickey
Mon May 22, 2006 3:29 pm
Thanks Cibernet but the only firewall entry of any kind that I can see is :
chain=srcnat out-interface=ether1 action=masquerade
which is there so that I can share the Public IP on the wireless interfaces.
cibernet
Long time Member
Long time Member
Mon May 22, 2006 3:38 pm
Ummm... that`s strange... what version of the Winbox loader are you using?
José Ignacio Acosta
Mikronet
bhickey
Mon May 22, 2006 4:06 pm
The Winbox loader is V2.2.8 freshly provided by the RouterOS itself. I've also tried clearing out the C:\Documents and Settings\username\Application Data\Mikrotik\Winbox folder first a few times but it makes no difference. I can provide an SSH login if that would be of any use?
cibernet
Long time Member
Long time Member
Mon May 22, 2006 4:11 pm
If you are using MT 2.9.24 the winbox loader should be 2.2.10..
José Ignacio Acosta
Mikronet
bhickey
Mon May 22, 2006 4:25 pm
Thanks Cibernet, I was running 2.2.8 using a shortcut to a previous download. Anyway I've dowloaded Winbox again from the node and when I connected it downloaded the plugins but I still get the same error. I can still connect via wireless using Winbox 2.2.9 and 2.2.10 and I can still connect via web and SSH.
bhickey
Thu May 25, 2006 9:26 am
Anyone else got any idea why I always get "connection refused" when I try to connect to the public IP of the RouterOS using Winbox?
Equis
Forum Veteran
Forum Veteran
Thu May 25, 2006 1:26 pm
Do you have transparnt proxy on?
I read that may be a problem
bhickey
Thu May 25, 2006 2:13 pm
Thanks Equis, there are no proxies on (see below). When I try to connect, it looks initially like it will work but then refuses. Does anyone know exactly what situation will cause Winbox to display the message "Connection Refused"?
user@MikroTik] ip proxy> print
enabled: no
port: 8080
parent-proxy: 0.0.0.0:0
maximal-client-connecions: 1000
maximal-server-connectons: 1000
user@MikroTik] ip web-proxy> print
enabled: no
src-address: 0.0.0.0
port: 3128
hostname: "proxy"
transparent-proxy: no
cache-administrator: "webmaster"
max-object-size: 4096KiB
cache-drive: system
max-cache-size: none
max-ram-cache-size: unlimited
status: stopped
reserved-for-cache: 0KiB
reserved-for-ram-cache: 2048KiB
janisk
Thu May 25, 2006 4:09 pm
does your user settings allow to connect through winbox?
bhickey
Thu May 25, 2006 4:15 pm
I assume so. I wouldn't even know how to resrict this. I can connect to both wireless interfaces using Winbox. The problem only exists on the ethernet interface. I can connect to the ethernet interface using www and ssh.
Users browsing this forum: No registered users and 19 guests
