rviteri
WDS setup between MK and Tomato Router
Mon Jun 09, 2014 6:04 am
I have a set up where I have 1 Tomato Router and 1 DD-WRT router are connected via WDS using WAP AES encryption.
I want to add a MK router rb2011uas-2hnd, but no luck still.
The current setup is like this Tomato ----- WDS ----- DDWRT, I want the following:
rb2011uas-2hnd ----- WDS ---- Tomato ---- DD-WRT.
Therefore, the only set up that would be required is the one on the MK router and the Tomato router.
I've tried many setups but I can't get it to work.
Does someone out there have any experience in this kind of set up and could share his or her configuration?
Thanks,
Ricardo
0ldman
Re: WDS setup between MK and Tomato Router
Tue Jun 10, 2014 7:49 am
What hardware are you running Tomato and DD-WRT on?
Your usual Linksys with Broadcom chips won't connect reliably over WDS to Atheros hardware. Sometimes it works, but it is a bit odd.
rviteri
Wed Jun 11, 2014 5:57 pm
Hi Thanks for the reply.
The tomato does have a broadcom chip. Anyway you would suggest a test that this would be in fact the case. I just want to discard that it is just not a configuration issue.
Thanks!
Users browsing this forum: Amazon [Bot], GoogleOther [Bot] and 58 guests
