MUM Europe 2020
mijabi
Esblishing new PTP wireless link with 200 Mbps (throughput)
Tue Jul 15, 2014 11:00 am
I would link to establish a link between tow point and I need to 100/100 Mbps (200 Mbps)
Can help me what wireless card and routerboard must be used?
Thanks a lot
jarda
Re: Esblishing new PTP wireless link with 200 Mbps (through
Tue Jul 15, 2014 11:40 am
If you already answered all the questions about environment, noise, distance, fresnel zone, local law requirements and others, then you can use whatever 5GHz device with dual polarisation, starting from sxt lite 5 for example. If it will fit depends on the topics I mentioned above.
nawas
Tue Jul 15, 2014 12:01 pm
Yes! Its possible. but if you can wait will be better because Mikrotik now is supporting 802.11AC and soon they will have a good 5Ghz 802.11ac outdoor products and you can use it for PTP with more than 500mbps throw-put :shock: :shock: :shock:
Users browsing this forum: cheeseliao and 31 guests
