MUM Europe 2020
1slava2
AR9888 channels with different width
Tue Sep 09, 2014 11:24 am
Hello anyone tried to buy a license to 6 AR98xx use a different channel width than 5, 10, 20, 40, 80 MHz. My question is whether the driver for the AR9888 allows the same set of channels as AR92xx. Thank you.
danielillu
Re: AR9888 channels with different width
Fri Dec 19, 2014 6:45 pm
I am having trouble when trying to set channels width of 5 and 10mhz on NetMetal5 (A9882 chipset). I can only set channel widths of 20, 40 and 80 Mhz (a/n/ac, n/ac, ac).
kinglyr
Thu Mar 05, 2015 2:12 pm
Hi!!!
The same problem here, i cannot set channel 5MHz or 10MHz on
Wireless (Atheros AR9888)
of a 921UAGS-5SHPacD
running RouterOS v6.26 with Firmware 3.22 (incl wireless FP)
On the other hand i can set 5MHz or 10MHz channel width on
Wireless (Atheros AR9300)
of a 912UAG-5HPnD
do you know why this is not supported when i press to apply 5 or 10 MHz says:
"couldn't change interface <wlan1> - bad band and/or channel, see ' wireless info ' for supported channels (6)
uldis
Thu Mar 05, 2015 4:11 pm
AC hardware doesn't support 5/10mhz channel width.
honzam
Thu Mar 05, 2015 5:16 pm
Is this information on wiki.mikrotik.com ?
LAN, FTTx, Wireless. ISP operator
lucky79
Fri Mar 06, 2015 8:26 am
Is this HW or SW limitation? Why Ubi support it then?
uldis
Fri Mar 06, 2015 11:14 am
In our AC radio datasheets it is mentioned that it supports 20/40/80mhz channel width.
czolo
Fri Mar 20, 2015 4:45 pm
Sorry, but for AR92xx was the same: in official datasheets where only information about 20/40MHz modes. So maybe it's possible?
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
Users browsing this forum: No registered users and 21 guests
