MUM Europe 2020
Insider
ŚXT AC mode
Mon Sep 22, 2014 2:59 pm
we made some fist tests with equipment with 802.11ac enabledin production sites in NV2 mode so we have AP withsome 5 clients.. Everything seems ok, but after some time there is some critical bug on Wireless to eth bridge. The client is hanged on AP all over, but datas are no passing bridge. The only solution is to restart device (but not always helps).
Then sometimes appear the log trigger System rebooted because of kernel failure. Used ROS is 6.19
Frequency microwave transvertors, design, development, manufacture
http://Pojitko.cz
zyzelis
Re: ŚXT AC mode
Mon Sep 22, 2014 4:02 pm
+1 i confirm this behavior. SXT-sa + SXTac
Insider
Re: ŚXT AC mode
Mon Sep 22, 2014 4:06 pm
Yes exactly
http://Pojitko.cz
ste
Re: ŚXT AC mode
Mon Sep 22, 2014 4:19 pm
We have reboots and complete hangups. Sent several supouts to support.
Seems not to happen with RB922UAGS-5HPacD only SXT.
zyzelis
Re: ŚXT AC mode
Mon Sep 22, 2014 8:46 pm
Insider,
how you have configured devices? as wds?
if yes, did you added to bridge wlan interfaces on AP side?
Does pings jumping if pinging to remote sites?
Insider
Re: ŚXT AC mode
Mon Sep 22, 2014 10:25 pm
Insider,
No, we dont use WDS mode any longer, We do use AP Bridge and Station bridge, and than adding interfaces to appropriate bridge
http://Pojitko.cz
zyzelis
Re: ŚXT AC mode
Tue Sep 23, 2014 8:35 am
[/quote]
No, we dont use WDS mode any longer, We do use AP Bridge and Station bridge, and than adding interfaces to appropriate bridge[/quote]
Thats interesting. what frequency mode you are using?
Could you change nv2 to nstreme? For me for now it helped.
Insider
Re: ŚXT AC mode
Thu Sep 25, 2014 9:36 am
Could you change nv2 to nstreme? For me for now it helped.[/quote]
We will try.. later today.. I got suppout rif, if MTik interested
http://Pojitko.cz
uldis
Re: ŚXT AC mode
Thu Sep 25, 2014 2:13 pm
Insider, please send those support output files to support@mikrotik.com
Insider
Re: ŚXT AC mode
Sat Sep 27, 2014 2:50 pm
OK, sent.. Anyway. Nstreme wont work at all. System reboot as wel, but it helped to upgrade to ROS 6.20RC.. At least it came up after
http://Pojitko.cz
Insider
Re: ŚXT AC mode
Tue Sep 30, 2014 11:02 pm
Anything new?????? It is really bad.. I have to restart SXT 3-4 times a day !
http://Pojitko.cz
fposavec
Re: ŚXT AC mode
Wed Oct 01, 2014 9:26 am
I use 2 SXT in PTP mode, as AP -> Station bridge. on 6.19 was issue with kernel on high load, but on 6.20rc5 was fixed and work OK
it is 20MHZ cahhnel.
50Mbit full duplex TCP , or cca 100 mbit on one direction tcp
Insider
Re: ŚXT AC mode
Wed Oct 01, 2014 9:36 am
RC20 does not solved. May be it is a bit better but Kernel failure continues..
http://Pojitko.cz
avenn
Re: ŚXT AC mode
Wed Oct 01, 2014 8:06 pm
I to have same/similar problem. Kernel failure - **AP and Client SUPPORT.inf files attached**
Using SXT G-5HPacD sectorial to one client using SXT G-5HPacD.
switched to 802.11n - no success
switched to 2omhz channels - this ACTUALLY CAUSED kernel failure
100 metres distance
checked radio noise - nice and clear
when I do BW test with 951s at each end to client falls over - this ACTUALLY CAUSED kernel failure.
see pics of AP and client
If 6.20 no fix then back to supplier and might have to pick AirMAX but would prefer not to. No choice.
Regards
Aidan
MTCRE - MTCNA - MTCTCE
Macek
Re: ŚXT AC mode
Wed Oct 01, 2014 9:07 pm
100 metres distance
Regards
Aidan
My all RB SXT ac ROS v6.20rc15 FW3.18.1 same problem - reboots during Freq. Usage, snooper :( the problem is not with you?
zyzelis
Re: ŚXT AC mode
Thu Oct 02, 2014 8:09 am
100 metres distance
Regards
Aidan
I can confirm that with 6.20rc15 device crashes during frequency usage scan.
squared
Re: ŚXT AC mode
Thu Oct 02, 2014 6:46 pm
+1 Same error with 6.20 final release.
100 metres distance
Regards
Aidan
I can confirm that with 6.20rc15 device crashes during frequency usange scan.
chernobil
Re: ŚXT AC mode
Tue Oct 07, 2014 4:53 pm
100 metres distance
Regards
Aidan
ohh, i confirm this problem. i lose sxt when i scan,freq. usage and... .
help please, and fix problem.
Insider
Re: ŚXT AC mode
Mon Oct 20, 2014 11:35 am
Download latest drivers, it seems that guys from Mikrotik made good job.. I got RC11 of ROC 6.21 on friday, from that time no restarts, no bridge malfunction! Yeeha, so we are getting to spam network with thees devices,
http://Pojitko.cz
lucky79
Re: ŚXT AC mode
Thu Oct 23, 2014 4:51 pm
They could have included the change in the changelog at least... No single word about it even you say its been fixed...
ton
Re: ŚXT AC mode
Mon Sep 14, 2015 11:54 pm
I'm facing the same problem, failure kernel version used 6.32.1, 6.30.4 already tested the version on the site mikrotik.com is defined as stable. I thank you to anyone who can help.
Users browsing this forum: zandhaas and 25 guests
