braidiano
routeros 5.24 and 5.25 stuck at 2Mbps and need reboot
Mon Sep 29, 2014 2:11 pm
we have some RB912 UAG (basebox) AP deployments (ap-bridge). They frequently stuck at a maximum throughput of 2Mbps (once a week) on WLAN, and need a reboot to recover. Next the reboot it works properly.
The config is:
# jan/02/1970 01:14:24 by RouterOS 5.25
# software id = 241I-12I6
add l2mtu=1600 name=bridge1
/interface wireless
set 0 adaptive-noise-immunity=ap-and-client-mode band=5ghz-a/n \
    disabled=no frequency=5560 ht-basic-mcs=mcs-0 ht-rxchains=0,1 \
    ht-supported-mcs=mcs-0,mcs-2,mcs-3,mcs-4,mcs-9,mcs-10,mcs-11 ht-txchains=0,1 \
    hw-retries=15 l2mtu=2290 max-station-count=70 mode=ap-bridge mtu=1522 name=\
    wlan3 nv2-preshared-key=aaannnnbbvv nv2-security=enabled rate-set=\
    configured ssid=AP-02 supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps \
    tx-power=20 tx-power-mode=all-rates-fixed wireless-protocol=nv2
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add bridge=bridge1 interface=wlan3
add address=172.16.2.50/29 interface=ether1
add address=192.168.51.1/24 interface=wlan3
add distance=1 gateway=172.16.2.49
/system identity
set name=Bts-01
/system leds
set 0 interface=wlan3
/system routerboard settings
set cpu-frequency=600MHz
Do you know if an upgrade to 5.26 will solve the issue?
plisken
Re: routeros 5.24 and 5.25 stuck at 2Mbps and need reboot
Mon Sep 29, 2014 5:47 pm
Upgrade to the latest 6.19
Upgrade de bios to
braidiano
Mon Sep 29, 2014 6:30 pm
I have about 300 clients in production, and I don't want to upgrade to 6.x untill they are stable. There are numerous problems reported on the forum about 6.x
CyberTod
Long time Member
Long time Member
Mon Sep 29, 2014 7:28 pm
There are problems. But they appear in specific scenarios.
The wireless improvements are many and noticable in wireless-fp package.
At least you can upgrade 1-2 devices to test if it works for you and is problem free.
zodiaco
Mon Nov 17, 2014 1:39 am
Upgrade de bios to
hi
this is my setup base Box + r11e-2hpnd
  I upgraded to 6.22 and still have the problems with the restart or shutdown.
1. what is the best version to upgrade basebox5
2. what is the maximum temperature to work well basebox5
3. I downgrade to 6.18 and tested.
ideas and solutions
Thank you.
plisken
Mon Nov 17, 2014 12:18 pm
We have the fewest problems with RouterOs 6.12
What we run: BGP-routing, EoIP tunnel, PPTP tunnel, no problems with this.
Don't forget upgrade the bios firmware.
zodiaco
Mon Nov 17, 2014 3:40 pm
Testing a BASEBOX5 v6.12 (RB912UAG-5HPND-OUT), I'll be counting results.
Not a PC
don’t forget upgrade the bios firmware
Thank you.
Users browsing this forum: No registered users and 29 guests
