MUM Europe 2020
andressis2k
Heterodyning in wireless networks?
Mon Oct 06, 2014 11:29 pm
Hello. I've installed 3 sector antennas in a tower with some FM stations (4 x 2kw each)
If I scan from one of the RB912, I can see the other two... and also a new "phantom" signal with 100MHz less
Considering that FM has a frequency about 100MHz... can be heterodyning?
I've never seen it in wireless networks... but what else can it be?
Regards
realtime
Re: Heterodyning in wireless networks?
Wed Oct 08, 2014 10:11 pm
The problem in a radio magnetic field.
I also encountered this problem.
Change the location of your antennas or FM antennas :)
tgrand
Long time Member
Long time Member
Fri Oct 17, 2014 9:42 pm
Using 10MHz wide channels aren't you?
If you were using 5MHz wide channels you would see the "ghosts" on both sides of your channel.
You can just ignore it...
EDIT:
No sorry.. I see that you are using 20 wide.
Have never seen this on 20MHz wide channels.
Users browsing this forum: Bing [Bot] and 27 guests
