MUM Europe 2020
andreacoppini
Trainer
Trainer
Antenna Alignment using RB532 LED
Wed Jun 14, 2006 3:52 am
Hi all,
I have just placed a tiny script on the MT Wiki which blinks the User LED on the RB532 (and presumably on the RB100 series) according to the SNR of the first entry in the Registrations window.
http://wiki.mikrotik.com/wiki/LED_Antenna_Alignment
Use at your own risk, tweak till you drop... enjoy 8)
- No strings attached -
<< Please give good Karma if this post helped you. Press the + button above the Location entry
Equis
Forum Veteran
Forum Veteran
Wed Jun 14, 2006 1:07 pm
Cool, Thanks :)
Can we leave it running on indoor RB's (so a quick glance could check status, and it looks neat) :-)
andreacoppini
Trainer
Trainer
Wed Jun 14, 2006 1:10 pm
Cool, Thanks :)
You're welcome
if a flashing bright red LED doesn't bother you, I guess you can... :-)
pcwiseguy
alignment
Wed Sep 27, 2006 8:21 pm
It would be cool to see the other two leds above that one light up based on snr to. Know how to make that work. Kind of like a bar led on an EQ.
jo2jo
Forum Veteran
Forum Veteran
Wed Sep 27, 2006 11:43 pm
really cool...thanks...i have it running on my home router to see when someone is using wifi...i have the schedueler set to 1 sec interval so i'll report back if this causes any errors but so far so good and very minimal cpu util. hit.
tks again
GotNet
Re: Antenna Alignment using RB532 LED
Thu Sep 28, 2006 1:33 am
Hi all,
The RB100s don't support "duration". We use an alternate with them; pulling the little speakers off and using the beep command. My real wish on a related note is to control the 3 WRAP leds.
Mike
matt
Thu Sep 28, 2006 12:28 pm
I think MikroTik should build these features into the software as there are a lot of other systems have LED status.
My 5c worth.
normis
Thu Sep 28, 2006 12:38 pm
yes, led stats for a specific device, but not for all devices. we can make it work with routerboards maybe
matt
Thu Sep 28, 2006 12:47 pm
Cool, look forward to seeing it in the next upgrade? ;)
Users browsing this forum: hakan0725 and 19 guests
