MUM Europe 2020
mrelusive
Replacing wireless card
Wed Oct 22, 2014 8:23 pm
I should replace miniPci card on my mikrotik because the power of the card is low.
Soo, what should I do before replace card, is there any advice how to do that because settings will be changed when insert a new.
Is there any solution to switch the cards and to apply setings from first (old) card to second (new) card?
gcs
Re: Replacing wireless card
Thu Oct 23, 2014 2:33 am
i take screen shots of the different tabs especially the wireless tab. after you set up new card don't forget to click on ip and address they will be red change interface to new card. check ip routes too.
lucky79
Thu Oct 23, 2014 3:07 pm
[admin@MikroTik] > export
# oct/23/2014 14:04:15 by RouterOS 6.15
# software id = XXXX-XXXX
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode \
band=5ghz-onlyn channel-width=20/40mhz-ht-above country="czech republic" \
disabled=no distance=1 frequency=5680 hide-ssid=yes ht-ampdu-priorities=\
0,1,2,3,4,5,6,7 ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=bridge \
multicast-helper=disabled noise-floor-threshold=-105 nv2-cell-radius=10 \
periodic-calibration=enabled periodic-calibration-interval=600 rate-set=\
configured ssid=NBB supported-rates-a/g=6Mbps tx-power=4 tx-power-mode=\
all-rates-fixed wireless-protocol=nv2
Then just paste this config when card replaced (maybe just rename the new card to whatever wlanX was the old one)
Users browsing this forum: No registered users and 51 guests
