MUM Europe 2020
samansenju
HOW TO SOLVE LOOPING BETTWEN BRIDGE ? RSTP ?
Mon Jan 19, 2015 12:58 am
i have topology like in the picture.
samansenju
Re: HOW TO SOLVE LOOPING BETTWEN BRIDGE ? RSTP ?
Mon Jan 19, 2015 1:02 am
i had enable rstp in every bridge. but still looping
samansenju
Mon Jan 19, 2015 1:07 am
samansenju
Mon Jan 19, 2015 1:15 am
for 4.4.4.4 (remote address) had changed to 1.1.1.2
samansenju
Mon Jan 19, 2015 10:56 am
thasser
Mon Jan 19, 2015 4:22 pm
Try a basic OSPF config and disable all of your rstp in all bridges. This is how I prefer to solve loop issues.
jarda
Mon Jan 19, 2015 11:45 pm
I don't think that ospf as ip route distribution protocol can help with bridge loops if someone needs to run bridges, because it is different level of iso/osi model.
samansenju
Tue Jan 20, 2015 2:23 am
yes i need to run bridge here, would you like to help solve my problem?, maybe give some clue for searching in internet
samansenju
Tue Jan 20, 2015 2:29 am
is it posible just bridge virtual interface like vlan or eoip without bridge real interface (ether1,.....) ?. i mean is it posible run without add real interface into bridge (will rstp work ?) to block a virtual interface (became alternate port)?
because when i looked rstp not bocking a virtual interfce became alternate port (role = alternate-port), in my case all interface bridge became dessignated-port and root-port (for eoip from sw_B to sw_a)
samansenju
Thu Jan 22, 2015 1:58 am
what protocol or port causing loop usually ? and what happend/effect if i drop it ?
samansenju
Thu Jan 22, 2015 2:01 am
is it enough like this ?
0 chain=forward action=drop
dst-mac-address=01:00:0C:CC:CC:CC/FF:FF:FF:FF:FF:FF
1 chain=forward action=accept in-interface=EOIP-400-ANTP mac-protocol=ip
dst-port=5678 ip-protocol=udp
2 chain=input action=accept in-interface=EOIP-400-ANTP mac-protocol=ip
3 chain=output action=accept mac-protocol=ip dst-port=5678 ip-protocol=udp
4 chain=forward action=drop mac-protocol=ip packet-type=broadcast
5 chain=forward action=drop mac-protocol=ipv6 packet-type=broadcast
jarda
Thu Jan 22, 2015 8:46 am
Maybe you can use routing instead bridging to get rid of these problems. Do you really insist on the bridges? If so, why?
samansenju
Thu Jan 22, 2015 12:44 pm
it is exiting topology buddy, i cant change it, i just can add it or increase it better
samansenju
Fri Jan 23, 2015 5:57 am
what happen if i block this "0 chain=forward action=drop
dst-mac-address=01:00:0C:CC:CC:CC/FF:FF:FF:FF:FF:FF" and block broadcast ?
Users browsing this forum: MSN [Bot] and 13 guests
