azurtem
Trainer
Trainer
Virtual AP across several APs
Thu Feb 12, 2015 7:20 am
Hi
I'm trying to setup an additional (SSID) AP for a site, accross four routerboards.
On each RB912 device, the wlan1 interface is bridged with the ether1 port, and an IP address assigned to the bridge
The wireless interface is set to apbridge
I then added a Virtual AP to each device, named wlan2, and ensured that wlan1 is it's master port
and assigned an IP address belonging to a different subnet than that of the bridge
The central, default gateway, device, an RB2011 2HnD, is also configured with the wlan2 Virtual AP
Now I'm not sure what the next step is; do I need to create a vlan linking the APs to the RB2011
to cater for the second IP subnet ?
thanks
yann
czolo
Re: Virtual AP across several APs
Fri Feb 13, 2015 12:17 am
Almost
I will recomend to create vlan1 for wlan1 and vlan2 for virtual-ap. Both vlans shuold be created on ether1, but you shuold delete ether1 from the bridge. Than just bridge vlan1 with wlan1, vlan2 for virtual ap, and create the same vlans on central rb.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
azurtem
Trainer
Trainer
Mon Feb 16, 2015 6:53 am
Thanks Czolo,
Users browsing this forum: timotei and 40 guests
