n21roadie
Full Duplex PTP over 7 to 14Kms
Fri Feb 27, 2015 2:10 pm
Anybody using Mikrotik full duplex (x4) in PTP links between 7 to 14Kms?
What throughput can be expected ?
N21roadie,
Network 100% MT for Now?
saintofinternet
Forum Veteran
Forum Veteran
Re: Full Duplex PTP over 7 to 14Kms
Mon Feb 01, 2016 6:05 am
no mikrotik products come in full duplex modes as of today.
you need 4 radios cards 2 on each side for full duplex to work.
by professionals, for professionals....
Don't forget to give KARMA!!!
scampbell
Trainer
Trainer
Mon Feb 01, 2016 7:15 am
Or use OSPF and 4 QRT's for example and base setup on http://wiki.mikrotik.com/wiki/Dual_Setup_with_OSPF.
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, MTCEWE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
saintofinternet
Forum Veteran
Forum Veteran
Mon Feb 01, 2016 10:25 am
thank you.
that looks interesting but has anyone deployed it in actual environment?
scampbell
Trainer
Trainer
Mon Feb 01, 2016 10:08 pm
thank you.
I have a few sites doing that - for example we use an RB850GX2 at each end and 4 x QRT's.
Set up two unique /29 subnets for each wireless link and the radio's as simple bridge (bridge/station-bridge).
Apply the different costs to the RB850 interfaces facing the radios so traffic flows in a clockwise (or CCW) direction and you will see uplink on one segnment and downlink on the other.
Disable one link to prove recovery. This gives full duplex and fail-over should one link fail.
Another way (not personally tried) would be to use bonding and two layer two bridges. This is not strictly full duplex but gives good aggregated bandwidth and failover :-) http://forum.mikrotik.com/viewtopic.php?t=70808
___________________
InoX
Tue Feb 02, 2016 1:01 am
I had for 2 years a link with 4xSXT bonded. It worked very well.
p3rad0x
Long time Member
Long time Member
Tue Feb 02, 2016 11:58 am
90% of our towers uses this method.
Usually we use LigoWave because they are more reliable in high noise environments.
For the other links where there is no interference we use rb912uag-5hpnd and bridge them.
Gets 100Mbps + both ways.
If one link dies ospf takes care of the rest.
I would say it works so well that if you don't have network monitoring you wont notice when one link goes down
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
czolo
Tue Feb 02, 2016 12:00 pm
What througput have you there?
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
ShayanFiroozi
Sun Feb 28, 2016 12:18 pm
guys you think interface bonding is better than OSPF full duplex ?? any real experience ?
thanks
The price of your knowledge which you have to pay is to share it with others !!
czolo
Sun Feb 28, 2016 7:13 pm
In my opinion: ospf is better.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
n21roadie
Sun Feb 28, 2016 8:44 pm
Can I ask the max distance between towers using this method?
N21roadie,
saintofinternet
Forum Veteran
Forum Veteran
Mon Feb 29, 2016 5:30 am
could you share your code used for bonding the 4 x SXT please? which device was used to bond them?
InoX
Mon Feb 29, 2016 5:17 pm
I've just found my first bonding result. Sadly the tutorial no longer exist. I've used 4xSXT and 2xRB750GL.
http://community.ubnt.com/t5/Business-T ... d-p/194143
Found it : http://wiki.specialistoff.net/index.php ... ti:Bonding
It was a better choice for me than full duplex.
saintofinternet
Forum Veteran
Forum Veteran
Tue Mar 01, 2016 5:55 am
the last link is in Russian... can it be seen in English?
ShayanFiroozi
Tue Mar 01, 2016 6:00 am
Google Translate :D
p3rad0x
Long time Member
Long time Member
Tue Mar 01, 2016 1:41 pm
The longest link we have is about 150km.
Using RBNetmetal 5's and the biggest dishes ubnt makes.
Signal is -57/-55 getting about 40-60Mbps
czolo
Tue Mar 01, 2016 2:18 pm
Respect!
Do you have any photos?
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
p3rad0x
Long time Member
Long time Member
Tue Mar 01, 2016 2:32 pm
Respect!
Not of the physical equipment, but I can share point A and B
I can share a screenshots of the signal and distance
czolo
Tue Mar 01, 2016 4:33 pm
It is something to be proud
Show us :shock:
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
p3rad0x
Long time Member
Long time Member
Tue Mar 01, 2016 5:10 pm
Hopefully wierd stuff don't happen to the layout
Link 1 Signal/Uptime/Distance
Link 2 Signal/Uptime/Distance
Link1 Signal/CCQ
Link2 Signal/CCQ
Link1 tx
Link2 rx
Google earth distance and elevation profile
saintofinternet
Forum Veteran
Forum Veteran
Wed Mar 02, 2016 12:17 pm
can i keep your photo around all my installations as an inspiration?? :)
are you having a clear LOS for 150kms? because i thought the earth's curvature spoils RF signals when you work in the GHz frequencies.
please correct me if i am wrong.
p3rad0x
Long time Member
Long time Member
Wed Mar 02, 2016 12:57 pm
That is true.
I haven't checked LOS when curvature is calculated.
For this link I only want stability, the tower at B are providing internet to mostly farmers with voip, since there is no cellphone reception.
I think it is near perfect because point A has a elevation of 1.9Km and B 1.1Km
Any good tool to check the fresnel clerance?
saintofinternet
Forum Veteran
Forum Veteran
Wed Mar 02, 2016 6:08 pm
That is true.
if you can PM or Email me the Co-ordinates i can send you the complete terrain details. i use Radio Mobile.
p3rad0x
Long time Member
Long time Member
Thu Mar 03, 2016 11:15 am
Co-Ordinates sent :D
victors0991
Sat Aug 05, 2017 7:07 pm
I dint understand. Can ospf double bandwitdh? Or only layer2 bondiing?
Users browsing this forum: No registered users and 23 guests
