QuicksilverW
Metal 9HPN for Point to Point through trees
Thu Mar 05, 2015 4:06 pm
I'm new to the forum, new to Mikrotik, and new to point to point wireless setups so I thought I'd start here for some advice.
I need to setup a point to point wireless connection between my company's main office and a nearby satellite office. This satellite office is about 1,492 feet away (0.456 Km) however there is a patch of trees between the two buildings. As it stands now, with the leaves gone, I can sort of see the office I want to connect to but when spring hits the view will be obstructed. See the Map below:
I know that 5Ghz and 2.4Ghz are out of the question so I was wondering what the possibility of making it through the trees with the Metal 9HPN would be. I would likely be pairing it with this antenna on each end: http://www.balticnetworks.com/laird-hd- ... id-nf.html
I need the link to be able to handle 5 thin clients for Windows Server 2008 R2 Remote Desktop Sessions, 2 printers, and in the future 5-8 VOIP phones.
0ldman
Re: Metal 9HPN for Point to Point through trees
Fri Mar 06, 2015 7:56 pm
That should work fine.
I've done much worse with XR9 and 13dBi yagi antennas.
edit: it does depend on your noise floor though.
Here, 900MHz is useless in the city limits. Works fairly well in rural areas though.
QuicksilverW
Sat Mar 07, 2015 12:03 am
Thanks for the info. The trees are pretty thick so I wasn't sure if even 900Mhz would work. As for city vs. rural we're pretty rural; it's a small town with about 6,500 people so, hopefully, there won't be much interference.
There is another possibility if anyone wants to chime in - we have another satellite office that's about 500m away that we already connect to with a Proxim Tsunami. This building has a clear line of sight to the new office, however, I'm afraid that I would see network issues if I tried to go from our main office ->wireless->Office A->wireless->Office B.
I appreciate the help as I don't have the budget to buy equipment to test with; this pretty much has to work first time out.
I may be able to talk my boss into getting a site survey - would this be the best route to go?
lcrhea25
Tue Apr 14, 2015 8:16 pm
What kind of speeds are you getting through you link? Just wondering before I look into getting some of these for my backhauls.
Users browsing this forum: IS0FFD, joserudi and 24 guests
