n21roadie
5.5-6.5GHz Dish Antenna
Fri Mar 06, 2015 12:19 pm
Any recommendations for a good 5.5-6.5GHz Dish Antenna! gain 24-30dbi
N21roadie,
Network 100% MT for Now?
ndor
Re: 5.5-6.5GHz Dish Antenna
Fri Mar 06, 2015 2:40 pm
Jirous , in my opinion , is the best on the market.
http://en.jirous.com/antenna-5ghz-parabolic
normis
Fri Mar 06, 2015 2:41 pm
why not use the same system all over? http://routerboard.com/MTAD-5G-30D3-PA
noyo
Fri Mar 06, 2015 4:44 pm
It good anten from Poland, 4,9 - 6,2 GHz
http://www.cyberbajt.pl/#s=DishEter%20PRO%20hv
n21roadie
Fri Mar 06, 2015 5:28 pm
@Normis
That dish quotes - Frequency Range 4.7-5.875 GHz ????
N21roadie,
n21roadie
Fri Mar 06, 2015 5:31 pm
@ndor
Parabolic antenna JRC-29 DuplEX Precision Frequency range 5,45 - 5,9 GHz ??
N21roadie,
n21roadie
Fri Mar 06, 2015 5:53 pm
@noyo Many thanks I will contact them.
N21roadie,
vladimirslk
Sat Mar 07, 2015 3:01 pm
you wanna mimo or single chain?
i have single chain svenska antenni spetsialisten SP60/54 and around 8 pcs. If you need let me know, i can ship them over EU (located Estonia)
n21roadie
Sun Mar 08, 2015 12:31 am
@vladimirslk sent you PM on Mimo option
N21roadie,
n21roadie
N21roadie,
Users browsing this forum: Google [Bot] and 28 guests
