TomosRider
Long distance links-best solutions?
Wed Mar 25, 2015 10:19 am
Hello guys...this is the story: we have one link on distance of 24km. 2 RB433 configured properly, signal is ok, CCQ great, but i have problems with connection and medium-access timeouts....i tried everything but problem still exists.
My main question is...what can i use to get stable connection between those links? I tried some solutions from other vendors but results were bad....rb433 was best solution atm, but can someone suggest something that will be more reliable than this?
Tnx in advance!
pixelkop
Re: Long distance links-best solutions?
Wed Mar 25, 2015 1:18 pm
which antenna you are using ??? which wireless card on rb433. why you are not going for basebox 5 which is 912 with MIMO antenna. what is signal level you are getting ??? LOS is clear ????
TomosRider
Wed Mar 25, 2015 2:57 pm
Sorry for lack of info.
I have AR92xx Atheros cards, LOS is clear, TX/RX signal is -54/-53 Dbm, CCQ 89%
skillful
Trainer
Trainer
Wed Mar 25, 2015 11:34 pm
Set Wireless Protocol to NV2 and configure NV2 Security.
n21roadie
Thu Mar 26, 2015 3:58 pm
What antennas are being used?
N21roadie,
Network 100% MT for Now?
ZeroByte
Thu Mar 26, 2015 4:01 pm
This sounds like it could possibly be an ack timeout issue.
When given a spoon,
you should not cling to your fork.
The soup will get cold.
TomosRider
Thu Mar 26, 2015 5:08 pm
@n21roadie-i dont know exact model names but i know that they were the best possible solution atm...colegues did the research and purchasing part.
@zerobyte-what can i do to tune this? I tried HW retries and TDMA setting, but i still have this disconects and that message in log.....tnx for hint anyway! :)
And yes, rb433ah's running on ROS v6.0rc7.
ZeroByte
Thu Mar 26, 2015 11:27 pm
In winbox, click the "advanced mode" button on the wireless interface configuration, then you will see more options on the wireless screen, but also a new "Advanced" tab where there is a setting for Distance (km)
It's better to have the distance too long than too short, so over-estimate your distance by a km or two.
Remember to do it to both radios.
When given a spoon,
jarda
Sun Mar 29, 2015 10:24 pm
Don't use old rc version. Update to some more recent version...
TomosRider
Sun Mar 29, 2015 10:47 pm
Tnx guys!! Will try this tomorrow morning...:)
CyberTod
Long time Member
Long time Member
Mon Mar 30, 2015 10:12 am
NV2 has improved a lot in recent routeros versions. So be sure to use latest version as others suggested. Also use wireless-fp package.
Also NV2 is not using the 'distance' value in Advanced. There is a setting called 'cell radius' which you only set on the AP.
TomosRider
Mon Mar 30, 2015 12:14 pm
Tnx Tod!
I will certainly update ROS and than test it.
TomosRider
Mon Apr 06, 2015 2:01 pm
Little flash update on this topic:after upgrading ROS to 6.27 and little tuning and listening to some of suggestions from you guys, link seems to be more stable than before. Zero loss of connection and clear log...awesome! Tnx again guys!
jarda
Wed Apr 15, 2015 4:19 pm
Great to read this. Enjoy!
Users browsing this forum: No registered users and 39 guests
