MUM Europe 2020
believewireless
Bonded NStreme vs. NStreme2
Fri Jul 14, 2006 3:40 pm
What is the advantage of using NStreme2 over bonding two NStreme connections? It would see that the dual NStreme connection would be more flexible in that it your bandwidth can be asymmetrcial vs. symmetrical with NStreme.
Is there a big advantage to NStreme2 I'm missing?
jober
Long time Member
Long time Member
Fri Jul 14, 2006 5:49 pm
Not that I can see.
One is half duplex and the other is full duplex.
I have a dual nstreme link that's getting 45/45mbps TCP or if I do the BWtester send or receive I get 66mbps TCP.
Seem like if I am getting 66mbps send and reveive then I should get 66/66mbps on both.
Maybe with bonding I could get 132mbps half duplex!
miahac
Long time Member
Long time Member
Thu Nov 09, 2006 4:10 pm
I think that bonding 2 links would be more reliable esp given you coud have channel-polarity diversity. What about bonding 2 nstreme2 links (4 radios)?
jo2jo
Forum Veteran
Forum Veteran
Fri Nov 10, 2006 2:03 am
what about the fact that you get no redudancy with NStream2 from what i under stand...you loose 1 of 4 antennas or radios you loose the entire link......right?
with bonding you can set it to fail over..
aviper
Fri Nov 10, 2006 9:02 am
Dual nstream is more "driver related". I had problem with dual nstreaming SR5 and 684HA cards (SR5,HA from one side, and SR5, HA from the other, I didn't have more cards to use 4 equal cards in both PCs :/). Soo I choose bonding 2 nstreams. Problem with the bonding is that one link can get up to 48-50 mbits and the other 60-65 mbits. But bonded together they can reach 95-100 mbits (soo I'm loosing around 15-20 mbits).
I'm not sure about the dual nstream.
But i prefer better way for bonding asymetric links:). (Clasicaly bonding is made for ethernet links I think).
normis
Fri Nov 10, 2006 9:28 am
we used this kind of test in some of the MUMs - multiple nstreme2 links were combined to achieve more than 300Mbits
Equis
Forum Veteran
Forum Veteran
Fri Nov 10, 2006 1:36 pm
:shock:
normis
Fri Nov 10, 2006 1:54 pm
miahac
Long time Member
Long time Member
Mon Nov 20, 2006 5:52 pm
frequency saturation
GWISA-Kroonstad
Fri Nov 24, 2006 8:58 pm
Found This. Gr8. Would two RBs on each side be enough for 100 Mbps?
jo2jo
Forum Veteran
Forum Veteran
Sat Nov 25, 2006 2:14 am
nope they would not be enought to get 100mbit wirelessly
jober
Long time Member
Long time Member
Sat Nov 25, 2006 7:42 pm
It doesn't seem like a good idea to use up 8 turbo channels to get that speed. I know it was just a test to see if you could do it. But, in the real world you wouldn't have many channels left to setup and other ptp links or APs.
GWISA-Kroonstad
Tue Nov 28, 2006 3:07 pm
Thx.
50 up 50 down?
normis
Tue Nov 28, 2006 3:12 pm
i think it is completely possible. even one router could do this. we have tested ~60Mbit one direction from one RB500 to another. two wireless cards in each (nstreme2). this means that if you use two such routers on each side, 100Mbits should be no problem.
jo2jo if you have doubts, please explain them.
GWISA-Kroonstad
Tue Nov 28, 2006 5:47 pm
Thank you Normis, well appreciated.
Now please check my 100 Mbps post .......
boardman
Fri Oct 12, 2007 6:28 am
A question on this:
- In bonding the main advantage is redundancy, but what about miss-ordered UDP packets like for VoIP applications? Have anybody here experienced that scenario? I mean a bonded link consisting of two wireless links and passing VoIP data.
Jorge Boardman
Users browsing this forum: No registered users and 33 guests
