jfvelamoscoso
Trainer
Trainer
Packet loss from antenna to routerboard on cable link
Mon Jun 15, 2015 6:02 pm
Hello, I have one antena Omnitik Connected as the picture attached
The antenna (AP1) is not replying to R2 neither R1 but AP2 is replying ok. ETH3 is slave from ETH2 and both are bridged to ETH1. The wear part is that if i disconnect AP1 to the network and connect a laptop with the same cable, it start working.
Any idea?
jfvelamoscoso@gmail.com
Network Engineer Noc Department
MTCNA, MTCTCE
If it helps please give some karma
rocknight13
Re: Packet loss from antenna to routerboard on cable link
Mon Jun 15, 2015 8:56 pm
Please paste R2 and AP1 configuration with status of all ethernet ports for both units.to find out the problem
regards
jfvelamoscoso
Trainer
Trainer
Thu Jun 18, 2015 6:15 pm
digging something i found this.
When the port eth1 on R2 is in the bridge I can reach AP2 but not AP1. When the eth1 is not in the bridge mode i can ping AP1 but not AP2.
Any idea?
MTCNA, MTCTCE
ericnyamu
Sat Jul 25, 2015 11:42 pm
Some info about the cable you are using maybe?
jfvelamoscoso
Trainer
Trainer
Tue Aug 11, 2015 6:17 pm
Cable UTP cat 6
MTCNA, MTCTCE
Users browsing this forum: No registered users and 38 guests
