MUM Europe 2020
jfvelamoscoso
Trainer
Trainer
Mikrotik AP vs Ubiquiti AP
Fri Jun 19, 2015 5:36 pm
I have been working with mikrotik for more than 2 years. I am playing with mikrotik radios but i want to see a fair comparison. Which mikrotik AP can be compare with which Ubiquiti AP.
  • Mikrotik SXT 5Hpnd VS Ubiquiti ?
  • Mikrotik ? VS Ubiquiti Nano Bridge?
  • Mikrotik ? VS Ubiquiti Nano loco
  • Mikrotik ? VS Ubiquiti Rocket dish?
Also if you know the diferences between (or complete list)
  • Mikrkotik SXT5HpnD
  • Mikrkotik SXT5Hpr2
jfvelamoscoso@gmail.com
Network Engineer Noc Department
MTCNA, MTCTCE
If it helps please give some karma
zyzelis
Re: Mikrotik AP vs Ubiquiti AP
Fri Jun 19, 2015 6:42 pm
You can't compare directly products because SXT = loco,nano(st,br),airgrid in short distances. In long distances mikrotik has no (complete) product to offer.
i have mixed Mt/Ub network and my thoughts are:
Ubiquiti definetily works better mikrotik when distances are >5km(due to antennas). But Mikrotik is cheaper and i see very good perfomance with mikrotik SXT's when distance is 1-5 km (even compared to ubnt).
jfvelamoscoso
Trainer
Trainer
Fri Jun 19, 2015 7:37 pm
For short distances? How can you compare SXT for example to Ubiquiti. I want to know if SXT 5Hpnd for example could be compare to air grid to loco or to nano bridge.
About lond distances, how about netmetal?
MTCNA, MTCTCE
chechito
Fri Jun 19, 2015 10:38 pm
air grid its 1x1 that makes no comparable, and have a high gain antennas, only for long distances.
i think loco its for very short distances because the open angle it mess the spectrum in a large area specially when using high power levels
Users browsing this forum: No registered users and 39 guests
