HiltonT
Dude Probes Across Agent
Fri Jan 22, 2016 12:24 am
In Dude 6.34 RC34 I found I was able to quite successfully scan a remote client network by configuring a Dude Server on the client network and configuring it as an Agent on our office network Dude Server. RouterOS, SNMP and other such services were detected and worked exactly as expected.
Under Dude 6.34 RC41 this has effectively all gone away. I can attempt to scan a remote network using an Agent, but nothing at all is detected. Even when I manually add the devices by IP on the remote network, although Ping and DNS Services are detected (yes, using the Agent), there's no SNMP nor RouterOS functionality (the tabs are bare of data). This makes monitoring anything other than simple connectivity to the network impossible (not to mention tedious to configure).
Regards,
Hilton Travis
krisjanis
Re: Dude Probes Across Agent
Mon Jan 25, 2016 11:19 am
Problem reproduced and reported to dev for fixing.
HiltonT
Thu Jan 28, 2016 9:46 pm
Thanks. Out of interest, the issue persists in 6.34RC45.
Regards,
Hilton Travis
HiltonT
Sat Jan 30, 2016 4:25 am
Also, even now RouterOS 6.34 has made it to Current/Production, this issue has not yet been fixed. :(
Regards,
Hilton Travis
krisjanis
Mon Feb 01, 2016 9:28 am
Unfortunately so. Bug report about the problem is still in DEVs queue.
mauricioisp
Tue Oct 01, 2019 9:52 pm
Hi krisjanis,
Do you have any update about this? I'm also facing this issue with version 6.45.5
billjellis
Sun Dec 01, 2019 6:03 am
Same here...
Bill
Users browsing this forum: Google Feedfetcher and 5 guests
