sajeeb
The Dude Client Update Problem
Mon Apr 18, 2016 1:29 pm
Mikrotik CCR1036-8G-2S+ router are using for our office network.
We also use The Dude Server in mikrotik router and version is v6.35.
Previous version is v6.34.
But when I trying to open The Dude Client from my PC following message have showed.
Do you want to update to version v6.35?
When I click to “Yes” Button following error message have showed.
dude.exe: cannot copy file
Please provide us a solution for above problem that will be a great help for us.
CyberTod
Long time Member
Long time Member
Re: The Dude Client Update Problem
Mon Apr 18, 2016 2:52 pm
This is a Windows problem (recent versions). You can not write to system folders even with a user who have full rights. You have to right click on dude.exe and 'Start as Administrator' then the upgrade process will complete.
sajeeb
Tue Apr 19, 2016 6:40 am
Thanks. :)
Its working...
Cappy
Fri Jun 10, 2016 10:31 pm
Same problem v6.35.2
Run as Administrator did not work.
Can i manually download dude.exe from somewhere else?
Thoughts?
Basdno
Wed Jun 15, 2016 2:50 pm
Thoughts?
Yes, I have same problem. I usuly just go to Mikrotik.com  download page and download the correct version client directly from webpage, then install it manually.
Cappy
Wed Jun 15, 2016 3:49 pm
Perfect, works!
reion
Sat Feb 10, 2018 7:44 am
Hi! Even if "run as administrator" the result is "bad http response from cloud". The only way is to uninstall current version, download and install needed version from mikrotik.com!
reion
Sat Feb 10, 2018 7:50 am
...but I'm very disappointed this time! The only available version for dude client, on mikrotik website is 6.39.3 (Bugfix only)!!! Need to downgrade my dude server!!!
chechito
Sun Feb 11, 2018 3:46 am
try 6.40.5 https://mikrotik.com/download/archive
Users browsing this forum: No registered users and 8 guests
