macsrwe
Forum Veteran
Forum Veteran
Low-end x86 for Dude Server?
Thu Apr 28, 2016 1:51 am
Removal of the Windows-based server in the new Dude is really inconvenient.
Whenever I network an office, facility, trailer park, or whatever, I have always created a little Dude instance that I can put on the administrator's PC, so he can see their setup graphically, tell what devices are up or down, and where the big traffic flows are. They always love it.
But now the new Dude works only on Tile and x86 machines. These customers are way under the Tile weight class, so that's out. I know there's some virtualization hoodoo possible to run the new Dude Server as a CHR on a regular PC, but my clients would have to buy virtualization software and know how to run and maintain it. It's just a troublesome deal all around.
What I'd like is to find a really low-cost, small x86 machine that will run ROS, just to run the Dude Server. The x86 machines recommended in the list all have big routing muscles -- I don't need that. I just need something small and cheap that can boot ROS, sit in a corner, do regular polling, and talk to the Dude client. The customer would have to eat the cost of this machine and an MT license if he wants this functionality, but I just don't see any way around this.
Meanwhile, I've been testing the new Dude using an old Intel Mac Mini as the server. I was super impressed at how it loaded and booted ROS out of the box with no hitches at all. But it's not a solution -- I don't have a source of old, used Mac Minis for my clients, it doesn't do powerfail-restart reliably, and unless it's attached to a display it won't boot at all on ROS.
Can somebody suggest some good options?
Sob
Re: Low-end x86 for Dude Server?
Thu Apr 28, 2016 2:29 am
It's not that bad, you can get free VMware Player or VirtualBox and create VM with CHR and Dude. And the only extra effort is if you want the VM to start automatically with Windows, because mentioned virtualization products don't have anything like simple checkbox to do that.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
kmok1
Wed May 11, 2016 6:27 pm
My Dude server runs on a 13 year old Celeron (2.4GHz) w/ 1 GB of RAM + 40 GB HDD. It runs fine, just has to schedule a monthly reboot since I think there is a memory leak.
Users browsing this forum: No registered users and 7 guests
