Ghaith93
error with running the dude [Solved]
Sun Aug 14, 2016 12:10 pm
Dears
I have issue with running dude after format windows , i remove visual c++ and reinstall but not working
please check attachments and help me
thanks
jarda
Re: error with running the dude
Sun Aug 14, 2016 12:29 pm
What dude are you talking about?
Ghaith93
Sun Aug 14, 2016 1:18 pm
dude client 6.34.2
jarda
Sun Aug 14, 2016 7:17 pm
I used that version some time ago and don't remember any problems. There are much newer versions if you want to try.
Ghaith93
Mon Aug 15, 2016 12:53 pm
Dears
i try another versions still same problem, :( :(
Ghaith93
Wed Aug 17, 2016 3:21 pm
Solve the problem with version 6.36
Users browsing this forum: No registered users and 36 guests
