MUM Europe 2020
isaacgrover
"get settings failed: std failure: broken path (2)"
Fri Oct 21, 2016 2:40 pm
Greetings,
On a new installation of The Dude, I am seeing the error "get settings failed: std failure: broken path (2)" when trying to connect to a remote RB750GL. The RB750GL is running v6.37.1, winbox to the RB750GL works, credentials are correct, and firewall rules allow all traffic from this workstation, so I'm not sure what else to look into. Thoughts?
Thank you in advance,
Isaac Grover
manulu
Re: "get settings failed: std failure: broken path (2)"
Fri Dec 09, 2016 2:46 am
Same here:
RB2011UiAS-2HnD-IN
Dude server: dude-6.37.2.npk
Dude client: dude-install-6.37.3.exe
Windows 7 32
running locally and also i want to know how to run it remotely.
leonix
Wed Jan 04, 2017 12:37 pm
solution: /dude set enabled=yes
Leo
manulu
Mon Jan 09, 2017 5:33 am
Leo
That doesn't work now i've upgrade it to
dude-install-6.38.exe
dude-6.38.npk
RB2011UiAS-2HnD
Windows 7 32
the error
no dude package
PaulsMT
Mon Jan 09, 2017 11:06 am
Dude can't be installed on RB2011UiAS-2HnD (MIPSBE)
The Dude server can be installed on following platforms:
ARM (RB3011)
TILE (CCR line)
CHR
X86 RouterOS
MMIPS
If you are using Windows, then the easiest way would be to install the CHR with Dude server on virtual machine.
Users browsing this forum: No registered users and 6 guests
